  New Posts New Posts RSS Feed - GT-40 Won't Idle Down
ddonaldson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddonaldson Quote  Post ReplyReply Direct Link To This Post Topic: GT-40 Won't Idle Down
    Posted: September-18-2015 at 4:48pm
We run a 1965 Nautique with a GT-40. Occasionally (not all the time) when we idle down from "high throttle" the idle down does not respond and the engine "runs away" and we need to resort to turning the engine off. Sometimes engine will restart at idle normally. Other times engine is hard to start, will crank several revolutions, then stop cranking. This may happen a couple of times. If repeated enough, (and sometimes with a little throttle) engine will start.
What's going on. As usual intermittent problems are a pain.
All help appreciated.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 5:17pm
Are you sure it is a 1965 with a GT40?
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 5:29pm
Do you have perfect pass on it?
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 5:30pm
Probably meant 1995, do you have perfect pass?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 5:39pm
Jimi died on this day.
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2015 at 9:51pm
27 years old....Excuse me, while I kiss the sky....scarily prophetic, eh?
1974 Southwind 18
1975 Century Mark II
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddonaldson Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 1:56pm
Forgive me - brain fart! 1996 Correct Craft with GT-40. Do not have Perfect Pass but do have Accuski. Have checked operation of the throttle control box of the Accuski and it is not hanging up (acting normally).
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 3:15pm
Idle Air Control Valve possibly?
Solution would be to clean or replace.
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 11:26pm
Disconnect the throttle cable from the throttle body. It is only 1 nut and note the location of the washer so you reinstall the same. Does it idle down? What is the volts read on the throttle position sensor when at idle? It should be about 1..05 or less. Best under just under 1..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 11:28pm
It could be as simple as someone bumped the bracket.that hold the throttle cable in place.. Can you send a picture of the bracket and throttle body with the spark arrestor off
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 11:47pm
Have you unhooked the vacuum line on the pressure regulator and see if the idle changes?
Tim D
