  New Posts New Posts RSS Feed - 1975 OMC manifolds
1975 OMC manifolds
Jbradford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jbradford Quote  Post ReplyReply Direct Link To This Post Topic: 1975 OMC manifolds
    Posted: May-16-2016 at 11:20pm
Original 1975 OMC manifolds, could be used for parts. The one riser has a hold in it down low that I did not want to weld up. They are in good shape other than that hole. I just decided it was time after installing a new crank mount pump and it blowing hoses from the hose size reduction. The thermostat housing is also included plus manifolds and risers. $100 plus shipping.
swilliams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swilliams Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2016 at 8:49pm
I would be interested in these. Do you still have the rwp? I posted in "parts wanted" for a pulley for the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jbradford Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2016 at 10:38pm
I do have the raw water pump and the manifolds. You can email me at jbradford64@gmail.com and I respond faster, I don't check the forum every day.
Thank you,
