  New Posts New Posts RSS Feed - Gauges jump when I turn on the Nav lights
karthur View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote karthur Quote  Post ReplyReply Direct Link To This Post Topic: Gauges jump when I turn on the Nav lights
    Posted: July-09-2016 at 8:07pm
I have noticed that when I turn on my nav lights... the ALT, Oil pressure and fuel gauge hands will all jump around like they have been shook real hard. They settle back down (on a reading higher than "normal"). Take for instance the oil pressure gauge... with the NAV lights off, it will read 40 psi... with them on, it will read like 50psi.
Is this a normal thing? I assume it is, I have just always wondered about it.
My boat is a 1987 SN.
Thanks
MechGaT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MechGaT Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2016 at 9:39pm
The ground on these boats are notoriously weak. It is daisy chained from one thing to the next. There is a thread on here about wiring a better ground and power source. Read that one & what you are seeing will sound familiar.
'92 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote karthur Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 2:02am
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 3:48am
Originally posted by karthur karthur wrote:
Is this the thread you are talking about?
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=21901&PN=2&title=added-new-dash-ground-to-93-with-pics
yep, that's the one.   I would suggest that if you haven't replaced the battery wire, that may be part of your issue as well.    use your VOM and check for a large resistance in the wire to tell you if it's not doing it's job anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 11:28am
Yep......nature of the beast on these boats. Winter project for sure. been on my list of things to do for about 5 years now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 11:47am
Tim,
You'll never get it done since you only get snow and or ice down there every 4 years or so and then it only lasts for a couple days!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote karthur Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 5:21pm
"....battery wire".....I found this wiring diagram for the 1987.
http://www.correctcraftfan.com/downloads/1987_dash.pdf
Is the battery wire here shown here? Or are you talking about the large battery cable coming from the positive battery terminal?
Thanks
