  New Posts New Posts RSS Feed - Bent Strut
Bent Strut
Dan in CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan in CT Quote  Post ReplyReply Direct Link To This Post Topic: Bent Strut
    Posted: July-09-2016 at 11:28pm
Hey folks,
1981 ski nautique
I removed my propeller shaft today, the new ARE is being shipped. Found my strut has a pretty good twist. Bearing worn on opposite sides front to back. I am going to look around for a pro to straighten but has anyone been sucessful in fixing a strut at home? I've got a big vice, the old shaft, and some heat...seems like this might be something that could be done.
If someone has one laying around let me know. After the cost of the shaft, my wife is going to be less than thrilled about another $500 for a new strut ( if even available).   Thanks, Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2016 at 11:49pm
Can you see the bend or is it measurable? Could it be that it wasn't mounted 90* to the bottom?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 12:45am
Dan,
Gary has a very valid point regarding how the strut was mounted. Take a real close look at it before condemning the strut. If it is bent/twisted, give the straightening it yourself a try. I've known guys who have straightened them while they were still attached to the hull!! A big 48" pipe wrench and a cheater pipe! Not something I would recommend but it's been done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 12:52am
Sounds like it could have been a misalignment problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan in CT Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 12:53am
I can see the twist in the casting. It is clearly damaged. I hit a rock last year. I got the prop fixed but it was not quite right since. Seems to be getting worse, Probably the bearing wearing. Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 1:04am
The old prop shaft could work as a 60 inch bar to bend your strut. Good Luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 11:37am
Just my 2 cents.......... I never tried straightening the strut myself after a friend drove the 88' too close to shore and bent it, the prop and the shaft after trying to grind a stump with my prop. years ago. I just bought a new pricey one and replaced it and the shaft and had the prop refurbished. ....... I bent the strut and prop on the 72 last summer and sent both struts to Delta Props. They were able to straighten both and installed a new cutless bearing ( at no cost as I pushed the old ones out). They didn't charge me much to do it and I was back on the water in the 72 in 2 weeks. That's why we all need 2 CC's....Ya gotta have a spare!
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 2:17pm
It takes a lot more force than you think to move the metal. Let the pro's do it.
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 2:44pm
This: Leave it in place and twist it back. Its easier than many think. Because of my boating venue I have become quite proficient at the process. I use a 15" crescent wrench and cheater pipe. But if I had an old shaft it would be my first choice. Put a new bearing in it and twist it back until the shaft is perfectly centered. (cold).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 3:00pm
But:
“Give me a lever long enough and a fulcrum on which to place it, and I shall move the world. ”
― Archimedes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan in CT Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 10:52pm
My first choice is to get the pro to straighten the strut out. I'll report back whether successful or not to find "a guy". If not, I'll give it a try. Does the forum's senior engineer (Peter) recommend heat? I could get the whole casting to 500 in the oven. Otherwise its a torch. Not sure if it much matters, its a big chunk of metal!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2016 at 11:48pm
Dan,
No on the heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan in CT Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2016 at 8:46pm
Dropped the strut off at Hale Propeller in Old Saybrook, CT.    Based on what I saw on the shelf, I hope their equipment works on "1"! There were bent struts that I doubt I could lift! Will report back. Dan
seacamper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 10:49pm
Sooooo. I hit some stumps and the strut is bent. I have the prop off and at Rob's shop, Can I get a jack from the trailer frame to the strut and apply pressure? If that does not work, can I ship the strut somewhere to have it straightened? I still don't know if the shaft is true or not.
Tom
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow
1988 Mastercraft Tristar Closed Bow
1969 Seacamper Houseboat
1986 Harris Pontoon
2004 Seadoo GTX SC + Flydive Xboard
1999 Adventurecraft
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2017 at 11:08pm
Isn't there a prop and strut place in Tampa that all the local shops send their stuff too? Maybe Admirals?
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 12:23am
I guess I can give them a try.
1986 Harris Pontoon
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 12:29am
I am inclined to try this first. So leave everything in place including the shaft, and just twist it back? Failing that, what is the cost to send the old one out for repairs vs. $350 new at Skidim?
1986 Harris Pontoon
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 1:25am
It seems to me I recall $75? Maybe that's for them to install new cutlass. Either way their prices seemed fair and the turn around time was quick enough even with shipping it was reasonable enough to ship it vs drive there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 5:49pm
Thanks Todd,
I called them and they said it was a function of shop time and said anywhere from $85 to $120ish. They also had a pickup and delivery from my local marina (I think you went there to look at a boat in Winter Haven). I should have it back Tuesday with the bearings installed.
1986 Harris Pontoon
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2017 at 6:53pm
I turned the shaft with a wrench and I can not see any problems. Although the prop strike bent the prop and the torque twisted the strut, it seems like the shaft survived. Do I have to remove the shaft to use a dial indicator? I will brush up on engine alignment, the prop lapping thread and I will keep the strut bearing wet when checking the new prop and strut, Anything else?
1986 Harris Pontoon
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2017 at 4:01am
Can you see .003" by eye?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2017 at 7:07am
Tom,
Have you straightened the strut? For the shaft, use a dial indicator clamped to the strut and it can be done with the shaft in the boat. With a prop strike, the typical shaft bend is aft of the strut so check there first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2017 at 11:49pm
Uh...............yes.................can't you? Oh. I forgot you did not get the Bionic Man treatment.
1986 Harris Pontoon
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2017 at 12:14am
Tom,
Hey Pete. The strut comes back from Admiral on Tuesday with the new cutlass bearings pre installed. . My plan was to install the strut over the shaft and put on the new prop and go run it, but I can get a dial indicator from Harbor Freight. So clamping the dial indicator to the strut will work? I've never used one. Will this work?
HF Dial Indicator
1986 Harris Pontoon
1999 Adventurecraft
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2017 at 2:10am
HF dial indicators will probably work for our applications. However, if you take a bit of time and check Craigslist, you can usually find a used Starrett for slightly more. They're useful for a ton of different projects. The difference between a proper US made and Chinese-ium is the Starrett doesn't get harder to depress as deflection increases. Not critical in our projects, but nice. I notice a difference between my Grizzly and Starrett
1999 Ski Nautique 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2017 at 7:08am
Tom,
Chris is correct regarding the quality of the HF but also that it will work. It will be interesting to find out the condition of your shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2017 at 1:39pm
Tom make sure to check runout just in front of the strut, just behind the strut, and on the actual taper where the prop attaches. These were the spots I noticed the most runout on the 2 shafts I tested. The promo shaft was straight as an arrow the entire length until the taper. Then it was waaaaaaaay out.
Give me a call if you need help.
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2017 at 1:41pm
Also rotate the shaft from the transmission and not the prop. If you have ANY play in your cutlass it will skew your results when you add pressure to the prop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote seacamper Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2017 at 1:55pm
OK, I will check it Tuesday and let you guys know. If worse comes to worse, I guess I will get an ARE shaft.
1986 Harris Pontoon
1999 Adventurecraft
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2017 at 5:14pm
On my boat the trailer has a brace directly under my prop shaft. It worked well to mount a magnetic mount dial indicator and check my shaft run out.
