  New Posts New Posts RSS Feed - Checking the Check Engine Light
Nauti Gator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nauti Gator Quote  Post ReplyReply Direct Link To This Post Topic: Checking the Check Engine Light
    Posted: August-02-2016 at 11:59pm
I'm replacing various odds and ends on the boat and just replaced the old check engine light because the red lens was missing. Then I wondered how do I "check" the check engine light to see if its actually working (from the senders) ? Do I put ground or 12v to the temp and oil sender wires and see if the red light comes on? I don't just want to assume it's working.
Thanks
s_kelley2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote s_kelley2000 Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2016 at 2:36pm
If your boat is setup the same as my 99 Super Sport then you should be able to confirm your check engine light is working by turning the key to Run but not starting the boat. I confirmed that is how mine works the other day. If that doesn't work for yours then I am not sure if it is activated by 12 volts or ground but I would guess 12 volts.
1999 Python Super Sport
