  New Posts New Posts RSS Feed - Drive Shaft Replacement
mwpdrp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mwpdrp Quote  Post ReplyReply Direct Link To This Post Topic: Drive Shaft Replacement
    Posted: September-23-2016 at 12:25pm
I am a new boat owner. Purchased a 1989 Ski Nautique 2001. It's been a great boat, but now I'm hearing some sounds at low rpm when the transmission is engaged. I'm thinking it may be the struct bearing. Was wondering if anyone as good advice on the procedure to replace the bearings. I know the shaft has to be removed. Little nervous on how to do it.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2016 at 12:35pm
Mike,
Is there play you can feel between the prop shaft and cutlass? Before you change the cutlass, I suggest using a dial indicator on the shaft to see if it's OK. Measure in the middle and more important aft of the strut since it's a typical spot that's bent. The T.I.R. should not exceed .003" If you do find it's bad, think about an ARE shaft system. It's will make the R&R of the shaft easy compared to dealing with the interference fit at the trans coupling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2016 at 12:59pm
Mike,
One more thing, do you think the sound you are hearing is coming from the cutlass? Describe the sound. If it's more of a clunking or rattle, it may be the damper plate between the engine flywheel and trans?
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2016 at 1:43pm
Yes, that's easier to rep[lace and correct. Its often exacerbated by a stumbly idle. It doesn't take much to make a racket.
If your boat has low hours, the cutlass is likely good as is.
River Rat to Mole
