2005 Nautique 196 |
frozenskier
Groupie Joined: September-19-2011 Location: northern ny Status: Offline Points: 102 |
Posted: September-27-2016 at 2:08pm |
I have a slow leak in an area that is hard to access. opened the trunk took out the carpet etc and I seem to have a small leak coming from somewhere around the area where the exhaust goes through the back of the transom. Quite slow, after sitting in the water the bilge pump only runs for 15 seconds or so after 24 hrs.
Any have this problem? Is it an easy fix? Ideas? Thanks. |
Hollywood
The hardest part will be finding the leak. Fixing it will be easy. You have to identify it.
Loose exhaust hose connection? Split/cracked hose? Non-sealed exhaust through hull? Of course the problem can be elsewhere, as the above is a rare problem. Rudder packing? |
Dreaming
you might try filling the bilge with water while the boat is on the trailer to see if you can get the leak to "flow" backwards. This could pinpoint the problem area.
Orlando76
I wouldn't lose any sleep over 15 seconds in 24 hours.
James T Brockma
Senior Member Joined: November-02-2007 Location: Indian Wells CA Status: Offline Points: 120 |
If you have not found the leak yet, here is something to consider. I had a a similar leak in my 2006 216. It turn out that the rubber mat the muffler lays on was cut a little short at the factory. After 8 years of rubbing against the "hump" in the bilge where the shaft goes through the hull a hole wore through the muffler. The tip off for me was a trickle pink antifreeze In the bilge running from under the muffler after winterization. I pulled the muffler, fiberglass patched it, installed a larger piece of rubber padding and now have a dry bilge (I use a small Tupperware bowl under the packing to catch the drips. I'm anal).
Jim '06 216
'98 SN 176 |
