  New Posts New Posts RSS Feed - Belt Tensioner help
Belt Tensioner help
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Topic: Belt Tensioner help
    Posted: March-11-2017 at 4:43pm
2011 PCM EXC 343.
Replaced my water pump impeller today and having trouble getting the belt back on. Specifically, I'm having trouble understanding how the belt tensioner works on this motor. Doesn't help that I have to look thru a mirror to see it.
To loosen the belt, I removed the belt tensioner pulley. Unable to figure out how to get enough play in that tensioner mechanism to get the pulley and belt back on. The manual hasn't helped much with this.
Can anyone explain how this tensioner works? There's got to be some sort of adjustment that gives you slack with the belt and then allows you to tension it after it's routed over all of the pulleys correctly.
Steve
2011 Sport/Air 200
Excalibur 343
2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2017 at 4:55pm
figured it out.
Steve
2011 Sport/Air 200
Excalibur 343
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2017 at 6:51pm
There should be a little diagram adjacent to the tension-er showing the belt routing in case you didn't see it. I found putting the belt around the largest pulley last is easiest.
Changing the impeller on my Excal DD with tools in hand takes 2 minutes max :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2017 at 9:56pm
yea I don't suppose it would take you more than 2 minutes to get the job done with tools in hand from your tool box-----
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2017 at 1:00pm
Unless it's Quinners Toolbox!
