  New Posts New Posts RSS Feed - Boat looses power quickly.
vince@scdjax.com View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vince@scdjax.com Quote  Post ReplyReply Direct Link To This Post Topic: Boat looses power quickly.
    Posted: May-06-2017 at 10:47pm
Engine runs fine for about 20 min then shuts down. Loses power quickly, will try to start but not getting fuel.
When i touch the fuel cell it is very hot.
changed all the fuel filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vince@scdjax.com Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2017 at 10:48pm
When it runs it runs great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vince@scdjax.com Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2017 at 10:50pm
Acts like a short in the high pressure fuel pump??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2017 at 11:00pm
Welcome Vince. We need more info- what year,what engine.how many hours,any of the pumps ever been changed ? How do you know it's not getting fuel,did you check fuel pressure ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote vince@scdjax.com Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2017 at 11:10pm
2005 pcm super air 210. Changed both fuel pumps, low pressure and high, changed water seperator and filters x2, changed fuel lines.
boat runs great for 20 min then dies quickly. the engine will crank, batteries are new optima.   fires slightly but sounds like its out of fuel.    wait 15-20 and it will start right back up and run great for about 10 minutes until something gets hot again and dies again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vince@scdjax.com Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2017 at 11:12pm
It has spark and good power to the starter. If a coil was bad it would still run on the other cylinders?
not sure about the fuel pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vince@scdjax.com Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2017 at 11:15pm
each time its does start it will run for less and less time before it cuts off again.
throttle out View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote throttle out Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2017 at 9:35am
Is the issue you're describing what brought you to changing the pumps out? Curious what brought you to changing both pumps? Also, what PCM engine are we talking about here. I will assume however that we are dealing with fuel injected engine, And can't imagine that it has not given a check engine light.
1989 Ski Nautique 2001 351 PCM w/ 1-1.23
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2017 at 11:24am
Need to know which motor, if it's a zr6 I would lean toward coil pack?? If Excalibur try replacing cap and rotor. Either way I would check and clean the anti siphon valve
