  New Posts New Posts RSS Feed - Engine serial number
Delhiski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Delhiski Quote  Post ReplyReply Direct Link To This Post Topic: Engine serial number
    Posted: June-03-2017 at 7:24pm
Need help decoding serial number.
SN= 340484. Labeled as pro boss. In a 1994 ski nautique but previous owner stated that engine had been redone. So trying to figure out exactly what I have.   Hr meter has 125hrs.
Also engine runs rough at low idle?
Thx for help
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2017 at 12:35am
Unfortunately the number does not tell you anything,it's the prefix that has the info. Here are two examples below,top one is a early 80's PCM tag bottom one a mid 90's one. It's the model number you need to tell what the original spec engine is. Any modifications done after it left the factory like an overbore,cam change,distributor upgrade etc won't be on there.
