Rear step plate attachment NWZ |
Dreaming
Posted: June-05-2017 at 4:04pm |
Anybody know what screws are used to attach the black aluminum step plate on a NWZ hull? Mine was removed at some point, and I don't know if I need to attach with screws and nuts or does it use sheetmetal type screws?
KRoundy
Kris - do you mean the two pieces that actually hold up the swim platform?
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2979 |
I assume that you are asking about the black step plate that is at the top of the "slant back" correct? Mine is mounted with six (6) black counter-sunk flat head screws. If you want, I can send you a picture.
JQ |
Dreaming
JQ, you are correct. The black plate on the top of the slant back.
The countersunk head part I am good with, but I need to know what kind of threads and how long the screws are. If they are coarse thread, or machine thread with a nut on the back side. If there is a nut, I'll likely have to pull the fuel tank to re-install. |
KRoundy
I'm 99.9% sure there is nothing on the other side of that plate. I'll look in my box of goodies tonight and see if I have a baggie labeled something like, "Step plate" with some screws in it.
Kevin |
Dreaming
Thanks Kevin! if you cant find any, I'll stop at Home Depot on the way home and pick some up [:y:}
