Airglide speedometer light |
jborzak
Groupie Joined: July-06-2006 Status: Offline Points: 97 |
Posted: July-12-2006 at 8:12am |
I need a light bulb and maybe the socket for an airglide speedometer. I found a light bulb socket that fits (5/8 inch) but the little hole for the bulb is about 5mm or 0.1969 inches in diameter. Where can you buy a bayonet bulb like that or buld and socket combination?
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
Can you use an LED? If you can you have many options and won't have to worry about the bulb burning out.
jborzak
I found the problem. The aluminum backert plate had a hole for the calibrating screw. I removed the gauge and found the real light bulb hole. Drilled the backer plate...now I have a light on the speedometer. Now if I could fix the oil temp gauge all will be working.
