  New Posts New Posts RSS Feed - Throttle shifter loose 96 Open Bow Nautique
Klundog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Klundog Quote  Post ReplyReply Direct Link To This Post Topic: Throttle shifter loose 96 Open Bow Nautique
    Posted: August-07-2017 at 12:37pm
Took the boat out yesterday and the throttle is loose and almost falling out. No issues starting, running, or shifting although neutral button does not engage as it should.
Praying it is not a hard fix?
Klundog
"Boats, vessels of freedom!"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2017 at 12:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2017 at 4:55pm
Just so you know when posting, your throttle body is actually on the top of the motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2017 at 5:03pm
Yup, the title confused me. I had to read the text a couple times to figure it out!!    But, it could have been stated as "the body of the throttle/shift is loose"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Klundog Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2017 at 5:06pm
I realized the error in reference to throttle body. Found the name "CONTROL SINGLE MV TELEFLEX – 1996-2012 BOATS" at NautiqueParts.com after the fact.
I will get a look under there tonight. I'm hopping it comes down to a loose locking hex screw.
Thanks for reply
Klundog
