79 Correct Craft 351 W Raw Water Pump |
LincolnPinch
Newbie Joined: September-29-2017 Location: Georgia Status: Offline Points: 7 |
Posted: September-29-2017 at 2:56pm |
Hello everyone.
Does anyone have or know of anyone that has a raw water pump to replace a Jabsco 17410. Believe new number is 18830. |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1781 |
DuaneinIndy can help you out. He will be around sometime and seems magical with metals and fabrication.
Andrew,
What's the problem with the RWP? Also, I linked rebuild kits for the 17410 in the other post you made regarding needing the pump. |
Duane in Indy
Thanks for the compliment Bill. Andrew, Give us some more info about your Jabsco pump. Yes they can be rebuilt several different ways. The ceramic/carbon seal is the tricky part of the rebuild. Take some pics of the pump, especially the flange end. Some flanges are pressed on and a real pain to remove in order to replace the bearings and seal. More info needed to assess the rebuild procedure. |
1978 Mustang (modified) |
Duane in Indy
Andrew, I found this on e-bay. jabsco 18830 pump |
LincolnPinch
The bearing housing cracked on the Jabsco 17410 so I guess I'll have to buy the replacement model. I just hope it bolts up the same as the old one.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11115 |
That all knowing thing called Google could probably help you out.
Here's one place They seem to have or can get what you need or a replacement Jabsco pumps and parts |
Duane in Indy
Why did it break?? They can be broken during disassembly. Being bronze instead of cast iron it is probably repairable. Got any pics?? Duane |
