  New Posts New Posts RSS Feed - Boat started missing, then wont fire up
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Topic: Boat started missing, then wont fire up
    Posted: August-02-2006 at 5:38pm
Last week I was pulling my neighbors son on his wakeboard and the boat started missing then quit. A few days later it started it again when I was wakeboarding. So I thought it was time to rebuild the carb, so I did and no improvement. Then it knocked off and wouldn't run. So I started checking everything, I even replaced the coil. Then I discovered the cap had two cracks and a pinhole.
Tim D
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2006 at 11:26pm
Tim D Rocks! Thanks for sharing.
Mullet Free since 93
95 Sport
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2006 at 11:50pm
Tim,
Funny how such a small crack can make such a big problem! She running ok again?
64 American Skier
62 Classic..
73 Ski Nautique
fredo68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 9:50am
my neighbor has a hurricane deck boat with a
4.3 w/40 hrs. on it, its a 04. however his was
doing the same thing they pulled the cap off and the contacts had 1/8 in of green growth
on them. why would a mrine cap have a paper gasket on it? changed cap runs fine.
fredo68
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 1:25pm
Paper gasket makes the unit a marine unit...seals off the cap from fuel vapor (or contains the spark which way you perfer to look at it).
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 1:31pm
thanks david, only dumb question is a not asked question.
gracias
fredo68
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 5:10pm
The gasket isn't all, the posts are brass.
Tim D
