Smoking/ rough at idle |
Oleeolson
Newbie Joined: March-17-2006 Location: United States Status: Offline Points: 17 |
Posted: August-07-2006 at 2:16pm |
1985 351 ford 500 hours
Smokes and runs rough at idle, seems fine at higher speeds with no smoke. Has newer carb which I rebuilt just to be sure. Newer wires, rotor, points, cap and plugs. Accelerates and runs fine at high speed Really puzzled |
David F
Is the smoke black? If so, could be that the carb is flooding the engine while at idle...a relatively common problem. A new fuel filter and carb rebuild should fix the problem.
Tim D
Lower the float.
Tim D
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
Possible power valve not torqued to spec or cracked
Munday |
David F
You know, I just reread the original post and he said already rebuilt carb, so I agree that the float setting is probably too high. My bad.
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13515 |
Well if David says float...it probably is. That is what I instantly thought as well, although I'm no expert.
waketique78
Newbie Joined: September-15-2005 Location: United States Status: Offline Points: 36 |
idle air screws
1978 Ski Tique, Skylon, Fatseat And Sacs for ballast
GottaSki
Could be mismatched gaskets on the PV or drippy venturis from float/needle problem.
There is really nothing you can do to your air screws to make the boat blow smoke. |
River Rat to Mole |
