Carb/PCV line ??? |
JR_VIC ![]() Senior Member ![]() Joined: June-05-2006 Location: United States Status: Offline Points: 175 |
![]() ![]() ![]() ![]() ![]() Posted: August-23-2006 at 12:09am |
I have a 1992 196 with the 351W HO. I am currently running an Edlebrock performer intake. My future mods list may cause a clearance issue with the carb and the engine cover. My question is if I remove the 1.5" carb spacer, the Edlebrock performer has a threaded plug on the rear of one of the intake runners. Can I install a barb fitting into this threaded runner and install my PCV line there instead of the carb spacer? I talked with Edlebrock and they said it can be used for this but again I just wanted to see if anyone has tried this with any success. I don't want to create any drivability problems.
Thanks! |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21195 |
Out of curiousity, what mods are you considering that would cause a clearance issue? A bigger flame arrestor?
Im running a Weiand Stealth my '90 and its ~1" taller than the performer. With a 3" flame arrestor and the 1" carb spacer, I cant close the motorbox, but only by 3/8-1/2". Im going to try and plumb my PCV port into a 1/2" spacer to gain the room I need. Ive read that plumbing the PCV to the intake manifold will cause the affected cylinders to run lean, which is not ideal. Other options to consider would be to use a shorter flame arrestor, or to get a new carb that has a PCV port. |
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
I don't agree with the leaning out theory that has been tossed around before. I'll have to discuss wiith and expert to double check. It's was done in older cars for years from the factory.
Munday ![]() Gold Member ![]() Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
I think if I needed extra height I'd make a little calm shell type base for my motor cover to sit on.
i've seen some nice pnes on here. Munday |
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Offline Points: 3365 |
in contrast, I have witnessed funny (lean)plug readings on a Century MkII with a 340, on plugs fed by the runner with the PVC plubing.
The engine has preignition I think is exacerbated from the lean condition but he's too deaf to hear it and too cheap too fix it..Maybe he'll hear the rod exit the block? Can you just tap into the intake higher, so more then one jug gets the vapor? |
River Rat to Mole |
depending on the carb if it is a holley with four idle mixture screw couldn't you richen up the back cyl's a little with that type of set up?
Unlikely, the air screws are ineffective once its off the slots and on the mains, when its making big heat.
River Rat to Mole |
your right.
I called Edlebrock again and just asked them what the hole in the intake was for, without leading them into using it for a PCV, to see what a different tech would say. He told me that port was a vacum port and could be used on a car for power brakes or other needs such as PCV etc. He asked me what I wanted to do with it and I said "Marine application, PCV line". He stated that would be perfect. I told him about my concern that you guys mentioned above about the lean issue and he said "We have no documented problems or issues with PCV lean conditions, that is the intended use of that port...vacum needs". It looks like that runner shares the rear two cylinders. Again...just wanted to check here first if anyone tried and had problems. I will try it sometime over the next few weeks and let everyone know how the boat runs.
Thanks! |
Just do some plug readings now so you have something to compare to later.
River Rat to Mole |
boat dr ![]() Grand Poobah ![]() ![]() Joined: June-27-2004 Location: United States Status: Offline Points: 4245 |
my '73 302 came with no PCV system ,would like to install one one this new 331 i am installing in my '64 Am. Skier.read the threads and i too had doubts about an install directly into the intake runner,so i called Ford Motor Racing @1-586-468-1356. have spoken to Ray several times over the years about some of the strange things that seem to baffle the boat dr. when asked about hooking it up on the runner vs. the plenum he says it does not know or care.PCV from one valve cover to the intake runner,the vent from the other valve cover to the flame arrester,problem solved w/no more oily film inside carb.......... boat dr
