Ski Boat Lift |
FredWSauer
Senior Member Joined: August-28-2015 Location: St. Paul, MN Status: Offline Points: 156 |
Posted: January-03-2020 at 4:58pm |
Looking for input on an overhead sling style lift. I purchased a used electric 4000# lift and after wading around my channel swamp area where I live, I don't think it is deep enough within the 50' from shore DNR deal to sit. I figure I need about 3.5' of water to have ski boat clearance 93SN. I measured from my trailer and from the waterline on the boat to figure out how far under water the boards need to be.
What's a good overhead lift or anyone think I could convert the one I have? |
- FWS
1993 Ski Nautique 1978 Glastron T-160 1994 Weeres Pontoon - Wife's Boat |
Fred,
What's the lift you purchased? Is it cradled of a cantilever? What's "the 50' from shore DNR deal to sit" Different states have different DNR regulations. Riparian rights? |
FredWSauer
It a #4000 electric Hewitt. It is a cantilever. A dock without permit can only extend 50 from shore and/or only be so many square feet and only so wide. I have done some searches for sling style; but, not with much luck. I see some really nice permanent style big post boat dock shelters. Actually, my issue is not the 50' thing; but, I think I could only extend out maybe another 6' before I encroach on the 'navigation channel'
- FWS
Thanks(1)
Fred,
This is a Shoremaster cantilever. It's in about 24" of water in the front and 30" in the back. NO problem with ether my Tique or the X55. |
zwoobah
Senior Member Joined: September-13-2018 Location: Providence RI Status: Offline Points: 308 |
I have a similar Hewitt lift. The front is normally in about 20” of water and it was hard to get the boat off the lift during a drought. I dug down under the feet and lowered it 2-3” this fall, hopefully that will help next spring. If you can get the front ends of the boards just barely under water it will work fine.
I’ve never seen a free standing sling lift - only see those in boat houses up here. |
1968 Mustang 16 - 351W powered
JoeinNY
Free standing slings used to be everywhere up here 40 years ago, then replaced by steel cantilever lifts, and then the aluminum vertical/cantilever lifts. We still have one steel sling hoist at my sisters camp holding a late 50s open aluminum sea nymph - I bet I have sawzalled apart dozen of them over the years. I used to consider them heavy and ugly but considering that most hoists now have canopies that make them heavy, ugly, and relatively complicated maybe they are due for a comeback. |
Duane in Indy
Does anybody use the "air bladder" system?? Air pumped into tank that displaces the water and makes it float then depletes the air and makes it sink. Looks like a simple system but must be a reason they are not popular. Air compressor, valve system and some hoses is all that is needed. Kinda like a floating dock compared to a sinking dock.
1978 Mustang (modified) |
jbear
Thanks(1)
Love the pontoon! We share a Weeres with our friends the Wightmans in Tennessee. Bought it from my brother. Great boat. We love it. Dont see many of these around.
john |
"Loud pipes save lives"
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
Duane, that kind of lift is pretty much the standard down here. I am guessing because we don’t freeze so they don’t have to come out in the fall. If folks have big boat houses, they may have some kind of hoist/sling/lifting ring system, (Reid comes to mind) but I’ve also seen a bunch with the air tank systems. Greg Fossett has a nice one, integrated into his floating dock. I don’t think they do real well in real shallow water like the OP has tho, those bladder tanks are fairly large/deep. I think HydroHoist is the prevalent brand.
https://www.boatlift.com/boat-lifts/ |
