  New Posts New Posts RSS Feed - Salt Water History
Salt Water History
RBFly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RBFly Quote  Post ReplyReply Direct Link To This Post Topic: Salt Water History
    Posted: May-03-2020 at 11:25pm
Advice please:
I just looked at an 07 SV211. It has a new Jasper 350 (new hoses / accessories) with 37 hours of fresh water time on it. The total time is 380. I am trying to get the records from the shop that put the motor in to understand the history. Based on what I saw on the skegs and swim platform attachments, it looks to me like it’s been in salt water with a previous owner.
Where else should I expect problems or should I take a closer look? Maybe ballast system?
How much does salt history affect resale if the new engine/accessories are fresh water?
Appreciate any insight you can share...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 12:46am
Folks will tell you 3-5 years on the manifolds if used in salt or brackish. As far as the ballast, certainly the pumps and valves would need to be looked at, and inspected.
Why the engine change at such low hours?
Plenty more questions to be asked on a relatively new-ish boat, that went through an engine change and really low hours....
Post Options Post Options   Thanks (0) Thanks(0)   Quote RBFly Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 1:07am
ultrurunner,
Thanks for the insight. Was just looking the records. Looks like everything on from engine, accessories, manifolds, pumps (bildge, fuel, ballast), steering cables, and gages, audio amp were all replaced. My guess is the boat was partially submerged, either dockside, or was launched without the plug. It became inop, and the Marine Dealer bought it and restored it.
It's pretty clean now, upholstery in good shape for a 2007, runs well. Talked to the Mechanic that did the work, and he wasn't sure about the history - just that they got it as a project. Then sold it to current owner who is selling for something bigger. What do you think?
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 10:15am
I think I’d pass. It might be a good deal but there will be another good deal too.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 11:53am
Any warranty on there work, one year ??
Price?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 12:02pm
Saltwater is one thing, a new block is one thing, a potentially flooded boat is a whole other can of worms that I wouldn’t want to tackle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RBFly Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 12:08pm
No warranty remaining. I spoke with the dealer that did the work. They sold to current owner who put 38 hours on it and wants a deep v cruiser. He’s asking 30.5. I an
considering 24-26 range given the history. It’s local and It currently runs very well, just not sure what problems could lurk in the future. Also considering a pass as was mentioned.
For comparison Found a 2006 211TE with 1400 hours but looks clean asking 28K. Also spoke to an owner of a 2007 211LE (no tower) asking 24.5 with 500 hours - but cost about 2K to ship that to me.
Contemplating all 3, or D) none of the above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RBFly Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 12:30pm
Thanks Orlando,
I’m not sure that it was flooded, just guessing based on everything that was replaced. The mechanic said they wen through and just tried to make it all new, but I’m trying to guess why it was all needed, and that’s what I come up with. Boat history is clean in terms of damage, but just trying to imagine what would likely cause that. Appreciate all the input on this topic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 1:12pm
Well, if this boat turns out to be some killer deal that you can’t do without, it would be easy enough to track down the original owner and get the scoop on what happened. That would be a minimum in my book. But, as you know, tons of other good boats out there, with more to follow.
rosconole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 2:34pm
probably ran it without oil , , I wouldn't be to worried about it unless it was totally submerged like a submarine.
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
Post Options Post Options   Thanks (0) Thanks(0)   Quote RBFly Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 3:07pm
Thank you...I've reached back to the mechanic that did most of the work for the Dealer, to see if I can get a better assessment on the history.
Appreciate all the wisdom being shared.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2020 at 8:53pm
If by chance it was submerged in salt water , you know what salt can do to electronics .
