Fuel stabilizer |
Slalom fan 4
Groupie Joined: May-09-2020 Location: Idaho Status: Offline Points: 73 |
Posted: September-09-2020 at 8:56pm |
I recently suffered a season ending event with my 93 sport where shop has transmission pulled and are waiting for rebuild parts on backorder. They sent her home til spring but I still need to winterize so how can I get fuel stabilizer through system. Any wisdom would be appreciated.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11155 |
Assuming it has a Holley 4 barrel, drain the float bowls and pour some stabilizer in the tank, shake the boat to mix it up some and don't worry about it.
Easiest way to drain the bowls is to pull one of the lower screws holding each bowl on. Put the screws back in and you're done. Or...........if you really absolutely gotta have stabilizer in those bowls, after they're drained, pull one of the top screws on each bowl and squirt some treated gas into the bowls and put the screws back in .
Slalom fan 4
Simple enough, thanks.
