  New Posts New Posts RSS Feed - Blown Motor, Looking for Suggestions
KingsPoint19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingsPoint19 Quote  Post ReplyReply Direct Link To This Post Topic: Blown Motor, Looking for Suggestions
    Posted: October-12-2020 at 8:04pm
Good Evening!!
I recently purchased a 74 Mustang, had been sitting for a couple years.  The engine was never winterized and the mechanic has his doubts on refurbing it.  What does everyone recommend?  Should I go with a short block and try to reuse the heads or play it safe with a long block/ drop in?
BWC
Best Regards,
BryceC
Acta Non Verba
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2020 at 8:37pm
I’m thinking I’d want a definitive visual diagnosis that the block is shot before making engine change plans.
Report back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 6:35am
Bryce,
What specifics is the mechanic saying about the condition of the engine? What tests if any has he done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 7:38am
Bryce
I'm gonna make this wild guess that you're in Belgrade Lakes Maine and another wild guess that an engine that wasn't winterized up there where it gets mildly chilly in the winter has some freeze damage Wink
I'd also figure that the exhaust manifolds would be damaged right about now too.
I'll also use my psychic powers and figure that you graduated from the Kings Point Merchant Marine Academy in 2019 and work at Bath Iron works
My psychic powers are named "Google" by the way. Wink
All that aside, there's a place in Skowhegan called Marshall Machine that sells rebuilt marine engines, long blocks, short blocks etc.
I used up all my powers and can't be sure what your engine is, but I bet you and your mechanic could go talk to them about options when you know what the issues are.
By the way...............welcome to CCF and nice area up there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 7:44am
Bryce
You could also send a PM to a member here, screen name "Riley" who's not too far from you and he could be pretty helpful with info and maybe parts too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 8:07am
Bryce
Bruce's (Riley) profile with a PM link:
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 8:19am
Bryce
Pete
I'd fix your "link" again, but you need to figure this out for yourself Wink
But as a hint, get rid of some of that junk before the www. when you're pasting it
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 8:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingsPoint19 Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 9:22am
Corrosion on all but 3 cylinders, cracked piston on cylinder 1, he wasn’t sure it would even turn over. Also a minor leak on the bottom of the oil pan
Best Regards,
BryceC
Acta Non Verba
Post Options Post Options   Thanks (0) Thanks(0)   Quote KingsPoint19 Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 9:25am
Bryce
Decent job, the internet is a wonderful tool isn’t it? Ill check out that place in SkowVegas
Best Regards,
BryceC
Acta Non Verba
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 9:29am
Well, with that, the motor is definitely coming out.
burban65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burban65 Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 11:40am
Keno (aka Columbo) - that's one the young ones on CCF won't understand.
I was going to go with Baretta but feel you may be more the Columbo type......just a guessSmile
SRB
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 12:50pm
Columbo for sure
And his most famous line was...............
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2020 at 3:30pm
Amazing just how little privacy we have these days.
Bath Iron Works...as a 4 year resident of Brunswick (do the math, and no, not the NAS) the big  BIW crane is a standout landmark
