  New Posts New Posts RSS Feed - Prop Nut and Cotter Pin Replacement
Otto Throttle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Topic: Prop Nut and Cotter Pin Replacement
    Posted: May-31-2021 at 1:45am
1999 SN running Acme 422... would like to replace the nut and pin when I check the torque on the prop. Who is a good supplier for both? What size nut and pin do I need?
Thank you!
Otto
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 3:23am
I don't have the requested size for the nut or cotter pin but if the prop was lapped in properly it will never move until you put a prop puller on there and Pull Hard to get it off.  The nut is just there as a safety in case the prop is not lapped you will not lose it.  No need to ever check the nut torque as that is not what holds the prop on.  Properly lapped a prop will seat itself on the shaft taper so tight in normal operation it will never fall off.
If your prop was not lapped in properly you can hear it whenever you drop into reverse, it will make a little clang as the prop slips back and knocks on that nut.   I got my first Nautique when I was 25, lots of time and always skiing but no knowledge.  I ran a prop without lapping it in for a few years before I had to change a prop, I pulled off the nut and the prop came right off into my hand, no puller needed.  The guy that sold me the new prop EXPLAINED things and I lap them now.  The advisors on this forum have taught me the by the book method for prop lapping and it really does work for smooth and safe prop operation.  Check in with Pete, I think he wrote the book on proper lapping and shaft alignment.
Prop Nut torque spec is only about 35 foot lbs, that is not a lot but it is plenty to seat the prop if it is lapped properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 6:05am
Otto,
You what a 3/4-10 nut. If you go with a "nyloc" type nut, then there's no need for a cotter pin. Also, do not use a stainless steel nut. With a SS nut on a SS shaft, there's a chace of thread galling (locking up) and then there's a big problem with removing the nut. Go brass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 2:02pm
Thank you gentlemen, I lapped the propeller using the Prussian blue and valve grinding compound Per the forums directions about three years ago. I was just looking around on the Acme propeller site, and they had instructions for installation and it included nothing on lapping the prop. I would like to change out the nut just because it’s older, and I don’t wanna have any problems. It’s always good to have spares around! At least that’s what my depression era father taught me! Happy memorial day to all you guys! To all of our veterans thank you for your service!
Otto
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 2:03pm
What about the stainless cotter pin size?
Otto
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 2:34pm
Ottto,
Did you purchase a castellated nut requiring the cotter? I don't have a cotter to measure so off hand I'd say the cotter would be a .125" or .093" diameter and a couple inches in length will do. If too long then clip the extra off. You'll be clipping the end off anyway.
Also, there's a correct way and a wrong way to cotter a castellated nut.
Wrong is on the left, correct on the right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 2:45pm
The lapping instruction isn't on the Acme web site. It comes on paper with their props.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 3:19pm
You could also watch their youtube video on how to improperly use a crescent wrench and how it also doubles as a hammer LOL
https://www.youtube.com/watch?v=1lmTW5lXA88
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2021 at 3:45pm
You'd think Acme's kit would have the proper tool. Using the adjustable as a hammer, sure is a true back yard hack job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 3:24pm
Just for your information, the cotter pin size is 1/8” x 1 3/4.
Otto
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 4:00pm
Good to know. Thanks. You'll have plenty of length to cut the ends off. Did you go with the castellated nut?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2021 at 4:19pm
Yes I did!   All from N3 Boatworks...Barb really helped me out. West Marine was clueless when I called them. Went with a sure bet!
Otto
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2021 at 8:20pm
And here's that paper that comes in the Acme box along with that big hunk of CNC machined casting
Rotating and making it bigger is optional.  Wink
