  New Posts New Posts RSS Feed - 1992 Correct Craft Nautique Dash Panel Switches
apolonie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote apolonie Quote  Post ReplyReply Direct Link To This Post Topic: 1992 Correct Craft Nautique Dash Panel Switches
    Posted: July-22-2021 at 9:12pm
Hey guys sorry for another question:
My dash panel switches' threading are broken, hence when I push on any of the switches they just fall behind the panel! I found replacement ones on nautique parts:
https://www.nautiqueparts.com/product/circuit-breaker-switch/
However I got some questions with a few of the amps and what nautique parts recommend the amps should be for each switch:
Lights / accessories: 10A (confirmed by nautique parts)
Blower: 20A ( nautique says this one should be 6A)
Ignition: 6A (nautique says this one should be 20A)
pumps: 7A (nautique says regular nautique is 2.5 amp, barefoot one is 8 amp)
Can anybody confirm one way or the other what the amps should be for each switch?
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-23-2021 at 5:39am
Blower and ignition are flipped so, blower is the 6A and the ignition is the 20A.
2.5A if you have 1 pump and then 8 if you have 2 bilge pumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote apolonie Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2021 at 10:24am
Thank you so much for the info!
