Nautique 206 will not crank. |
jenglemn
Newbie Joined: May-17-2015 Location: Austin Status: Offline Points: 12 |
Posted: September-13-2021 at 5:46pm |
Hello,
I have a 2003 Nautique 206 (PCM EX 330 GM) and it will not crank. The battery is now new. The starter works and is new, can be jumped, and the relays are all new and good. The lanyard switch is good as the dash pod gauges lights up after the code is entered. The Alternator is now new. The neutral switch is good. When jumping the starter, it will not start. When I push the start button, I can hear the relay clicking, but no starter. Where should I go now? Thanks! |
