Ah Snap! |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2949 |
Posted: September-18-2021 at 9:19pm |
I took my Ski Nautique to the lake this morning. A couple of weeks ago, I sold my Toyota 4Runner, so I needed to borrow a tow vehicle, as my new F-350 won't be built for another 4-5 months. My daughter was kind enough to loan me her Ford Explorer with a V-8. The Explorer ran fine for about 90% of the trip. As I was coming up the last hill on the freeway, the engine suddenly lost power and the engine sound was "way off". I applied a bit of throttle while scanning my gauges and reached out with my Spidey Sense to see what was going on under the hood. Damn. Oil pressure gauge at ZERO. Not good. So I start navigating as quickly as possible to get onto the right side emergency lane. As I'm moving over, I feel the engine "let go". RPMs drop to zero and white smoke is pouring out everywhere. Damn. Under the hood, there is oil everywhere -- and a hole in the side of the block that wasn't there this morning. Double damn.
The worst part was when my daughter started to cry when I told her that I re-named her car the Ford Exploder. Maybe I'll give her the F-350. JQ
Family or not that's why I don't like to borrow stuff. That is just my kinda luck as well. Whats the plan now? Good luck to you what ever way you go.
Jonny Quest
Well…since it’s really MY vehicle that I gave to her makes this a bit less painful. I do all the maintenance for her and when it needed tires in June, I paid half. She really can’t complain too much. She is “the Princess” so she’ll come out ahead… JQ (from in the doghouse)
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1194 |
Usually the other way around
‘Daughter blows up dads new truck’ |
gun-driver
I think she will be just fine with driving that new truck, while you repair the damage you did to her vehicle or find her the appropriate replacement. 😂😂
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
Ouch JQ, that is a bad day, at least it happened on the way home. It hurts more when you don’t even make it to the lake. Complete new engine might = time for a replacement vehicle depending on how many miles it has on it. Could list on Craigslist as a Mechanic Special.
I will edit: if it has 125,000 miles or less a new 4.6L engine or used replacement will fix you up. If above that number I might consider it time for a replacement unless that vehicle is in very good shape everywhere else. The 4.6L is actually a very reliable engine normally and they run a long time. The oil pumps were undersized and people that ran thicker than factory spec oils had issues, usually spun a rod bearing. Melling makes a larger oil pump for these, I have installed 2 or 3 of them, with the Melling pump you can run 10-30W oil. I think the factory said 5-20W oil. If you choose to install a used engine it would be worth taking half a day and installing a new timing chain and guides along with the larger Melling Oil pump, that makes the engine very good for long term use and it is not much money.
Jonny Quest
206,000 miles on the clock. That little Ford really doesn't owe me much. I'm strongly considering what you are suggesting and listing it on CL and the local online marketplaces as a "mechanics special" for $900 or thereabouts. I'm curious as to how much it will bring. JQ
