  New Posts New Posts RSS Feed - new to me 2000 Ski Nautique
audiodude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiodude Quote  Post ReplyReply Direct Link To This Post Topic: new to me 2000 Ski Nautique
    Posted: September-30-2024 at 3:20pm
I just purchased a 2000 Ski Nautique with an upgraded 350 chevy motor and zero off.  I was looking at the engine trying to find block drains and couldn't find any.  On my 1989 2ohoh1 351 Ford there are four block drains.  I ski all year so for winterization I drain the rather than use antifreeze.  Anyone know if and where the block drains might be?  I am away from the boat but will post some photos when I get back.
Thanks,
Art
2000 Ski Nautique 1989 Correct Craft 2001
In the words of Milton Berle: "You can lead a man to Congress but you can't make him think"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2024 at 4:08pm
Hey Art. Nice upgrade. Looking forward to a pull behind it. Sorry we didn’t get together down here for a little bit of course action. I got out some, but not much due to some back issues that culminated in surgery about a month ago. But I will be as good as new next summer and we will get together here or there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2024 at 5:25pm
In the picture below, the brass fitting is screwed into the block drain.
On the right side it's halfway between the front and back of the engine at the bottom of the block above the oil pan, a little ways in front of the starter like in the picture.
Same place on the left side, halfway between the front and back
Depending on what model you have, you might have plugs screwed in those holes or a knock sensor screwed in on one side and a plug in the other......or some variation on that , but whatever's in the holes, that's where the block drains are located. Wink
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2024 at 10:39pm
or a knock sensor on both sides.. most of the three bolt DBW throttle bodies had two knock sensors in the block. the four bolt versions with the larger ecm only has one knock sensor and a brass plug on the other side of the block.. Reminder to not put any sealant on knock sensors or teff tape when you reinstall, there should be plenty patch lock on the threads for multiple winterizing..
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiodude Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 8:19am
Thanks Keno and Jody, I will look for the plugs, I did see the knock sensors on one side.  So it's ok to remove the knock sensor to drain the engine?  Would a tee work so a petcock could be installed to drain the engine  so the sensor wouldn't have to be removed each time?
Larry sorry for the back problems but glad you are on the mend!  I look forward to getting together in the summer but if you ever feel like coming out this winter grab a dry suit and come on up!
Art
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 2:01pm
I use a 1/4 inch tee fitting like this......1/4 inch male NPT with  2  1/4 inch female NPT
Then screw the knock sensor into the 90 degree hole and use a 1/4 NPT pipe plug (or the petcock you mentioned) at the end,
That way you can stick something straight up the drain hole if the hole or fitting gets plugged with sediment, rust etc.
Sometimes a wye fitting is used there, but it's harder to stick something up to do some unplugging.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 3:26pm
I haven’t done much homework on this but I would hesitate on changing the mounting of a knock sensor if you intend for it to continue functioning correctly. It works by picking up engine vibration- pulling it away from the block on an additional structural member (y/extension/tee/etc) could disrupt its ability to detect knock or even falsely detect it, I would think. I know removing to drain the block is a pain, but might want to do a little more research, first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2024 at 8:09pm
I did enough homework a handful of years ago to tell me it was worth a shot.
It kinda went like this.....the PCM part number for a SBC knock sensor that I had (R020027) cross referenced to plenty of other companies like Mercruiser, Volvo Penta, Indmar, Crusader, Sierra.
They all used  the same GM supplied knock sensor in their SBC engines around late 90's into the 2000's, or in the case of Sierra sold one to replace all the part numbers from the OEM's..
Some screwed into the block, some screwed into a wye fitting with a drain plug on the other leg of the fitting.
Same sensor screwed into that big hunk of metal block a little differently.
Asked myself if I thought that the ECM's and knock sensor modules were calibrated differently for that little wye connection, said to myself "I doubt it" and gave it a try after doing some reading about knock sensor relocation kits for various engines and whether a new sensor was used or just the old one relocated..
I used a tee like mentioned above, instead of a wye.
Nothing changed, engine ran fine.
Did I do any highly scientific testing?  Nope, just a little logical backyard hack thinking and testing.
I'm sure it could be argued all day long about whether there's an effect, but that's for somebody else to do Wink
I guess we all have different comfort levels with certain things, so it's a do your own homework kind of thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiodude Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2024 at 10:50am
OK dumb question, does anyone know what the up/down buttons on the key panel are for on my 2000 Ski Nautique?  I looked in the  manual and couldn't find any information as to their function.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2024 at 11:48am
On your SN they do.nothing,,,,except make you wonder what they do  Wink
On a V drive Super Sport or Super Air Nautique with an electric jack to lift the engine hatch they raise and lower it
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiodude Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2024 at 3:12pm
Thanks Keno!
