Engine dies when rapidly closing throttle |
Wilhelm Hertzog
Senior Member Joined: June-14-2014 Location: Cape Town Status: Offline Points: 337 |
Posted: December-21-2024 at 9:32am |
My engine tends to die when I close the throttle suddenly - like when maneuvering at low speed to dock and having to quickly shift from forward into reverse. Searching the web suggests that:
Any thoughts on the above? Anything else that could be causing this? |
1982 Ski Nautique PCM351W RR II Velvet Drive 10-17-003 1:1 II PerfectPass Stargazer
Do not go gentle into that good night. Rage, rage against the dying of the light. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11142 |
I think I'd richen the idle mixture using the 2 idle mixture adjustment screws on the metering block.
If you're adjusted right now for max vacuum and you have a 150 rpm drop when putting it in gear like you say, richen things up going out about 1/8 turn at a time on both mixture screws and see how it acts. You should end up with less RPM drop( 50 to 75 or so) and better response going from neutral to forward or reverse
Wilhelm Hertzog
Thanks, I'll give that a try and report back.
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3759 |
I think Ken is leading you correctly. My 78 Nautique had the same issue. West Coast Correct craft was only 10 minutes away back in the 80's when I had the issue. They gave me the same advice and it worked.
Check your advance mechanism in the distributor to make sure it is rotating smoothly each and every time you advance and release the throttle.
