  New Posts New Posts RSS Feed - New Seats for 84 SN 2001?
wesman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wesman Quote  Post ReplyReply Direct Link To This Post Topic: New Seats for 84 SN 2001?
    Posted: January-05-2007 at 1:35pm
Help! The driver's seat in my 1984 Ski Nautique 2001 is falling apart, as the wood is rotted and the only thing holding the seat together is the upholstery! Although the observer's and rear seats need to be reupholstered, the wood structure appears to be holding up. Any advice on whether I should "rebuild" the driver's seat using marine/treated wood and reupholstering everything to match, or should I buy new seats with a plastic frame? If I buy new seats, which mfg would you recommend? Do the seats for newer correct craft boats fit? Does the mounting pattern for the newer CC driver's seat match the one on my boat? I really like the newer CC driver's seat, especially the flip up cushion! The only concern with putting new seats in my boat is the loss of "stock" status. Thoughts? Recommendations? Thanks in advance for any and all help! This is an awesome forum!
Wesman
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2007 at 3:15pm
The cheapest and easiest solution would be to build new bases. Dont bother with treated or marine plywood- exterior grade will be more than sufficient. If you coat the base with epoxy resin (making it virtually waterproof) you will extend its life considerably.
If you are creative with your design, you may be able to incorporate a flip up seat with the right hardware.
Either Midwest CC or White Lake Marine should have the original patterns for your interior. If you give them a sample of your current vinyl they should be able to match the colors very closely (even if faded) if you want to replace only certain pieces. A local shop would also be able to match- just make sure they use good quality vinyl and UV resistant thread.
SkiBum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiBum Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2007 at 6:40pm
I rebuilt the seat frames (bases or whatever) in my 87 SN. I used 1/2" plywood (not treated or anything special). I laminated it with epoxy resin and fibergla$$. Then I was able to just replace the foam. That is an inexpensive yet quality repair.
In the future I have plans to convert the driver seat to a flip up design, add some stylish curves to the observer bench seat, and make the three piece rear seat into one. I'll build the bases and take the existing upolstery to the local shop for revisions.
You should be able to handle this project. Just be sure that if you staple your upholstery back that you use stainless steel staples (available at Lowes, Home Depot, Ace, etc...)
Good luck
Bill
http://www.freewebs.com/billsboatworks
www.freewebs.com/billsboatworks 1987 SN Rebuild Project
