Glueing vinyl to dash |
liveintegra
Newbie Joined: August-20-2006 Location: United States Status: Offline Points: 33 |
Posted: April-09-2007 at 11:38am |
The vinyl on my dash is cracked and ripped. I tore the old stuff off and I already bought new vinyl to replaced it. I plan on steaming the vinyl so i can get it done in one piece and make it seamless. My question to you all, is what kind of glue should i be using.
Thanks for any help. |
1971 Martinique
contact adhesive but make sure you have plenty of hands to help lining it up. Once it's in place, it's there to stay
liveintegra
is there a good way to lay it down. I know that you cant really pre-cut it because your angles will change when you follow the grooves. So do you have to cut it as you lay it down?
1971 Martinique
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
To me seems like that would be the best way, just take a piece thats quite a bit bigger then what you need, use the contact spray, stretch it as much as possible & tuck or roll it where possible & trim the rest. I'm not completely sure what your dash looks like so thats just kind of general idea of it all i guess. Good Luck & lets see some before & after pictures when you get it done.
Nate |
