  New Posts New Posts RSS Feed - over heating
over heating
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Topic: over heating
    Posted: April-22-2007 at 5:24pm
I have a thermo electron concuerer crusader 220hp 302 .
The engine seams to be over heating intermitently for the last couple of years . Last year I thought I had it fixed . When I went to Green Lake it ran fine the first day but over heated the second . Then it came backdown and ran fine . I checked all the hoses for crud but didnt find anything but little pieces of rust scale . I blew through all the holes to be sure they were coming out where they were supposed to .I have replaced the impeler and the thermostat . I have not replaced the circulating pump . I have not had an impeler loose an ear since I have owned it for 13 years . I dont think there is any blockage
today I ran it in the driveway with a water hose going into a bucket and sucking the water out with the intake hose that was disconnected from the bottom of the boat.
it stayed around 145 but occasionaly rose to 165 . Should it stay lower . Any help would be helpful. Does the impeller have to have a prime before it will suck water ?
Thank you
Pat
Pat
My 72 Skier
Rock River
Dixon,ILL.
Munday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Munday Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2007 at 9:42pm
Nope self priming,I'd check everywhere for a slight air leak the pump will pull air instead of water every time.Even the threads on water pickup if you have any pipe fittings.
Goodluck
Munday
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2007 at 3:25pm
Impeller seems to be working ok . It pumps about 4 gals. in 15 seconds . I opened the petcock on the side and reved up and water sprayed out . Then I put my finger over the petcock and felt pressure, This leads me to believe that the circulating pump is good . I took out the thermostat and it still over heated . IM LOST !!!!
Thanks, Pat
Pat
My 72 Skier
Rock River
Dixon,ILL.
rudderdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudderdad Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2007 at 2:54am
How old are the hoses? You could have one sucking closed.
rudderdad
