  New Posts New Posts RSS Feed - Cold water boating - what to do??
dmoney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmoney Quote  Post ReplyReply Direct Link To This Post Topic: Cold water boating - what to do??
    Posted: September-24-2004 at 5:57pm
I live in Wisconsin and have a 1992 SNOB, and unfortunately, the temperatures will begin to drop below 32 degrees in a matter of weeks. I would like to continue to ski through October, but don't want to risk cracking the engine block or anything else. I keep the boat on a lift. When do I need to do something additional to the boat to extend my season, and what do I need to do to the boat exactly when I'm done running it for the weekend and put it back on the lift for a week? I'd like to hold off on winterizing the boat as long as possible. Thanks.
jcawley3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jcawley3 Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2004 at 3:22pm
how cold does the water get? I ski all year in the winter the water is 59-63 degrees air temp dips below 30 every now and then. I always drain the block after skiing and have not had any problems
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2004 at 3:20pm
I have, on occasion, put a light bulb (burning of course) under the engine box whenever the temperature was expected to dip below freezing and I had not winterized the boat at the time. The light bulb should keep the engine area warm enough to prevent freezing. Just make sure the bulb does not touch anything that will catch fire or be damage by the localized heat.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2004 at 3:58pm
You can get the drain kit from skidim, then all you have to do is turn a valve and the water will drain out and when you want to go again just close them and your ready.
