Electronic Ignition Conversion |
new86owner
Groupie Joined: August-02-2004 Location: United States Status: Offline Points: 78 |
Posted: October-11-2004 at 10:55am |
Has anyone here converted to electronic ignition? I am looking to convert mine and wondered if anyone had any experiences with any particular brands.
I have been looking at the Pertronix conversion kit. http://www.vintageperformance.com/retrorockets/ford-.htm They also have a kit at skidim.com http://www.skidim.com/prodinfo.asp?number=RP173072&variation=&aitem=7&mitem=35 Let me know of your experiences with any of these kits. |
john_33617
Guest |
best thing you can do to that engine , this is for a clip down cap http://www.amarket.com/imptppp8.htm
882001
Senior Member Joined: October-21-2003 Location: United States Status: Offline Points: 332 |
i did option a and would recommend it.
kemah texas
1988 skinautique "2001" |
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
I did my 66 and it worked great.
Tim D
It's worth every penny. I converted my '66 mustang about 7 years ago. You get quicker starts and improved throttle response. I had my friend who owns a NAPA store order it for me out of one of his books, about $90. You'll need the model and number of the distributor and check to see if there is a vent hole on the side of the metal part just under the cap, sometimes that makes a difference on parts, I know it does for the cap.
Tim D
NAUTI84
Senior Member Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
I ordered everything from SKIDIM.
Conversion Kit was $99.00. (I also went thru everything else while I was doing it Cap, Rotor, Wires, Plugs. But you didn't have to do that.) Was pretty easy to do. Old plate with points/condenser comes out of distributor & The new kit replaces it. Only other thing was that you had to by-pass the external resistor. Snipped wire each side & connected them. I also bought a new electronic coil to go with it ($33.00, again wasn't required SKIDIM said it would work with the old one) Last summer I had trouble starting & it was running rough - Now starts on first turn of key & purrrs like a kitten! So far, I'd highly recommend it! I'd also highly recommend SKIDIM. They were very helpful! |
logicsound
Groupie Joined: July-24-2006 Location: United States Status: Offline Points: 46 |
ok so how come when i go to skidim the price is 149 not 99. am i missing something (86 martinique)
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21186 |
Looks like the price went up within the last year. I know when I looked last april, the Prestolite conversion was only $100.
This post is from October 2004. |
logicsound
is there a diff between the skidim one for 149.00 and the one at amarket.com for 69.00
john33617
Senior Member Joined: July-07-2004 Status: Offline Points: 182 |
amarket has the best prices , starters, alt's , trans kits , ebasic for manifolds
Barracuda
Moderator Group Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
thanks fellas- you just reminded to order the conversion kit and tune up parts.should have it just in time for the summer-ization
