Need help with slipping clutch |
curbsidegold
Newbie Joined: December-07-2003 Location: United States Status: Offline Points: 33 |
Posted: November-04-2004 at 1:49am |
I have a mid 1960's Graymarine 4-75. It has the Capital gear system. Reverse works like a charm, but under load in forward position, the clutch slips causing the engine to race along with loss of forward momemtum. If I lean heavily on the gear lever I can gain some traction in the clutch.
I have tried adjusting the drawbolt on the clutch, and have even tightened to the point of beginning to strip the head of the drawbolt, but I can't seem to get the lever to 'snap' into forward position. Has anyone out there had a similar problem or has any ideas of either adjustment or repair? Thanks. SM |
sm
captan1
Senior Member Joined: June-02-2004 Location: United States Status: Offline Points: 180 |
Yea, don't let your son take it out with out you.
curbsidegold
Other than kicking the kids out of the front seat ... did you come across a more 'mechanical' solution
sm
