Gasoline causing black mold |
baitkiller
Posted: January-05-2017 at 7:58pm |
Its ethanol. Look under the gas cap cover on your car.. same stuff. Big G doing their thing.
Mr. Mold-It-All
Newbie Joined: January-05-2017 Location: New Jersey Status: Offline Points: 1 |
Especially since it is a boat and the northeast is already prone to humidity issues, there could be other underlying issues promoting the potential mold development. The gasoline may not actually be the source of the issue. If it is even mold, it can be the result of a number of water sources (ie: ventilation problems, etc.). The only way to know for sure would be to consult a professional and have it inspected.
http://mastertechmold.com/ http://mastertechmold.com/mold-inspection/ http://mastertechmold.com/mold-removal/ |
SNobsessed
I think the mold issue needs to be publicized, esp. since they are thinking about mandating E15. Maybe let the new sheriff know about this!
Now that this is mentioned I have noticed this on some of my cans,does not matter if they are metal or plastic ones but they are all older. Metal ones are from the 60's plastic ones from the 80's. Cleans right up with Publix mildew remover and does not come back for a very long time. The ones I have in Florida are the newer plastic ones and I can get gas here with no alcohol so I have not seen the same problem here.
Blamey
Gold Member Joined: August-18-2015 Location: White Plains,NY Status: Offline Points: 631 |
I have seen this on my boat at the back by the gas tank.
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme |
BIGJIMO
Newbie Joined: December-03-2016 Location: New Jersey Status: Offline Points: 1 |
I have been searching on and off for this mold topic as I have wondered much of the same as discussed here. I first noticed it immediately the fall of the year E-10 was introduced (somewhere around 2006 or 2007? in NJ). SRoberts pictures above; I experienced first hand, not on one sailboat, but almost all the ones we serviced at the marina I had worked at until 2009. It was around all the portable fuel tanks in the cockpit of the sailboats. I worked at this facility from 1988 on many of the same boats and never saw this in the fuel lockers before. The only variable was the fuel change with E-10. Shortly, I started to notice the mold on various plastic jerry cans that were stored outside. I think they were more prone to condensation being outside. My plastic cans stayed clean till recently, as I started to store them in a ratty shed. Until 3 years ago (approx 2013), they were stored in my garage when I started to notice a little mold on the ceiling over the area. I suspected the vapor thru the sealed plastic fuel approved containers. Now, the garage, which is detached and non conditioned, has mold seemingly starting to rapidly take off inside. It can be humid in there in the summer but so is everyone else's garages! I now contribute this to an old truck that I keep in there in which does not have a sealed fuel system and seems to always have a fuel odor around it. I think it is feeding or promoting the mold. I would like to keep the truck in the garage, so the next thing is either a de-humifier or better ventilation or both?? I see it around the gas filler doors on cars and even my Wellcraft center console boat. This boat has an in hull tank and access ports in the floor. When I open the ports, there is a black slime on the top of the tank. The other bilge areas also have blackened up over the last 5-6 years and now are disgusting. The fuel lines and filter/water separator all turn black, along with the fiberglass around the area. I do not know if it is related, but I now have health issues (muscle and joint pains-disabling) similar to Lyme disease symptoms and I can not clean up behind this thing because of limitations. I have also been recently diagnosed with a toxic mold exposure but do not know if it is from this or not. It may have been from another source possibly as I had stuff tested. The results were of a non toxic type in the garage. The mold illness diagnosis is based on new studies. Google surviving mold and Ritchie Shoemaker for more on this. As I googled more, I also found on Wikepedia a particular type of mold that grows around distilleries because of the vapors. "Baudoinia species use ethanol for their carbon nutrition, Ethanol in vapour form also accelerates the growth of the fungus and stimulates spore germination." etc. That is not the species in my garage but there you go anyway. Any help on the matter or suggestion for each other would be great. I would like to see E-10 go away or more studies on this done.
bhectus
Platinum Member Joined: July-04-2010 Location: Gator Country! Status: Offline Points: 1809 |
Wow, that looks serious! Black mold is nothing to mess around with. I'm surprised we haven't heard more about this. Tim Benjamin, where are you? Are you experiencing any of these symptoms up in CT where you are?
'87 Barefoot - sold '97 Super Sport Nautique - originally custom built for Walt Meloon '97 Ski Nautique '83 SN 2001 |
sroberts
Newbie Joined: August-25-2013 Location: USA Status: Offline Points: 2 |
I plan to use bleach, then pressure washing, then Concrobium. I read about it at Practical Sailor (http://www.practical-sailor.com/issues/36_6/features/Mildew-Prevention-Sailboat_5933-1.html) and can get it from the local home improvement store. We'll have to compare results.
Manny1969
Newbie Joined: August-21-2013 Location: New Castle Pa. Status: Offline Points: 2 |
I seen your pictures and that is what my garage looks like. After searching the web I found and ordered a product that sounds great. http://biocidelabs.com/BioCide100.html also http://biocidelabs.com/Mold_Bomb_Fogger.html
sroberts
I have the same problem with the fuel locker in my sailboat. There is no question that the gas fumes somehow contribute to the mold growth - the matching locker that stores my anchor has no mold. I've had this locker perfectly clean a couple of times over the past few years yet the mold returns with a vengance each time. This time after I clean it I plan to remove the gas tank and fuel line when I'm not using the boat to see if that prevents the problem.
gun-driver
Now this is interesting because I'm just south of you in Evans City and I have a 1/2 dozen 5 gal cans of gas that I use and have never seen any mold. But I will start paying more attention to see if it pops up. |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6150 |
I have seen black stuff on the inside of fuel doors on some of the cars we had that sat outside for long periods of time. But the same stuff would be in the door hood and trunk jambs so it clearly isn't relational to fuel.
NG, Since you say the black mold is "under" the containers, it's not from the gas. I happen to work for a blow molder of HDPE fuel containers and know we go through BIG EPA regs as well as an independent certification of fuel permeation through the container. The HDPE wall is actually 5 layers. One is a very special barrier to prevent migration of fuel. |
boardersdad
Senior Member Joined: June-18-2013 Location: Wisconsin Status: Offline Points: 409 |
I've never heard of this before.
Manny1969
I am having the same problem, I live in western Pennsylvania. I keep on hand 8 5gal red plastic containers for my generator. I have done this for the past 10 years, now all of a sudden I am getting black mold under all the gas containers. What are they putting into the gas? I called the CDC and they said they knew nothing about it. I turned it over to our local newspaper, hope they find something. Mold is nothing to mess with.
adamt
Gold Member Joined: July-18-2007 Location: Orlando, FL Status: Offline Points: 927 |
Maybe this is Mold Man's boat... |
-Adam
1973 Skier |
David, Where were you 2&1/2 years ago when the problem came up? What model boat do you have? We'd love to see it. Post some pictures. |
The Mold Expert
Newbie Joined: November-22-2010 Location: Manalapan NJ Status: Offline Points: 2 |
(url=http://www.absolutelyspotless.us/)
(url=http://www.absolutelyspotlessmold.com/) |
NJ
The Mold Expert
That black mold is tough to get rid of. Try Microban Disinfectant Mold Killer. These two companies do a great job with Mold Removal, Mold Remediation, Mold Testing, Mold Inspection, Mold Abatement, Mold Cleanup in New Jersey
http://www.absolutelyspotless.us http://www.absolutelyspotlessmold.com |
NJ
SNobsessed
Funny, I live in Iowa, home of Ethanol. But we still have the option of pure gas or E10. I opt for the pure gas myself. Ethanol has only 50% of the energy content of gas, so E10 really isn't a bargain, even at 10 cents a gallon less.
TK-421
Newbie Joined: October-14-2007 Location: United States Status: Offline Points: 26 |
I too think it is the corn content as it holds more moisture.
Really doesn't matter where I store them. In my shed under my shed or just plain sitting out in the sun like my big 30gl caddy. They all turn black. |
RT1963
Newbie Joined: April-17-2008 Location: United States Status: Offline Points: 11 |
The black stuff on my gas cans I see is mold. Usually caused by moisture.Where do you store your gas?
Party Smart!! Always have a bottle opener in you Boat.
adamt
Maybe it's that crappy corn oil they're "watering" down the gasoline with?!? What's the percentage of ethanol they're hiding in the fuel in your state?!? |
-Adam
1973 Skier |
TK-421
All of my red gas cans and my dad's have this black residue all over the outside. Car gas caps same thing.
I'll call Jamie at MB and get them on it right away. |
I have never seen or even heard of this problem. If you did a search and couldn't find any thing, maybe it's not the gas?? I too have a gas caddy and in the 12 years I've had it, don't see any evidence of black mold.
SNobsessed
Sounds like an investigation needs to be done... 60 minutes, Congress, Mythbusters??
TK-421
That is usually the response I get from people outside of CT USA.
I have one of those 30 gal fuel caddies from Boaters world and the entire outside is turning black. The inside of our gas doors on our cars are all black. The only thing that worries me is it doesn't like to come off of vinyl. If I leave the boat cover on for any length of time the black mildew like mold will start to grow. As long as there is adequate ventilation like using a tarp tee pee configuration then it will be fine. This is why I am trying to acquire a lift with canopy. That would give me the ventilation needed. We used to have a chemical called MTBE in the gas. People started having health problems with it so they switched to something else. We have only had this issue for the past 6 or so years. |
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Do you have one of those 2-cycle Nautiques that take mixed fuel?
Steve |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
SNobsessed
Where are you getting your gas from - Mafiamart?
TK-421
I have searched the forum and internet and can't seem to find info on the black mold caused by gasoline. I am not sure about all parts of the country but in the northeast they put something in our gas that causes anything nearby to turn black. All of my plastic gas cans are black. It power washes off fine but it looks terrible. The real problem is with a boat cover on the fumes from the tank vents etc also cause the same black spots on vinyl, fiberglass etc. I called CC in Orlando and asked them about it and they have never heard of that problem before. So any guys in the northeast know anything about it and what to do about it?
