Carb problem? |
jcawley3
Groupie Joined: January-31-2004 Location: United States Status: Offline Points: 82 |
Posted: April-23-2008 at 12:47pm |
I just put new plugs, wires, cap, button, points on it last week and have not run it.....they should be fine right?
the old were a year old and looked really good....only one was pretty black it was the last one on the left side |
Tim D
A good starting point is screw it all the way in, then back out 1 1/2 turns. Then adjust as needed.
Tim D
saffer
Senior Member Joined: March-29-2008 Location: New Zealand Status: Offline Points: 113 |
Hi Guys
Could you please give me the correct settings for the air screw on a stock 351's holley carb (ie turns from "all the way in" etc) thanks |
Tim D
When flooding, if you push the throttle wide open, it should start. After you get the carb fixed, install some new spark plugs.
Tim D
jcawley3
thanks
k.o.
Senior Member Joined: January-11-2008 Location: Aruba Status: Offline Points: 363 |
the rebuitl kit at skidim is 46 dollars i'm not from the states. i paid about 60$ for a mechanic to put in the part
jcawley3
ok, what's a ballpark price on a rebuild?
k.o.
yes the carb leaking is the starting problem we had the same thing happen same symptoms ours the first time was a debry in the floot stayed open and flood the engine and this time it a worn out needle since the last mechanic didn't replace it.. i think you are better of doing a rebuilt to be shure it doesn't do it again for now..
jcawley3
86 SN 2001
when boat has been sitting for a few days it starts very fast almost before you turn the key all the way......but.... If I shut it off and try to re start, it will take about 5-8 seconds to re fire....I took the spark arrester off and looked down in the carb....after shutting motor off gas continues to slowly drip....is this the problem? is it flooding itself out? how can this be fixed? adjustment or rebuild? thanks for the help. -John |
