connecting rod numbers |
Post Reply | Page 12> |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Posted: May-31-2008 at 4:08pm |
Brian, please post on here what grind numbers Cam Research recommends. You are using GT40P heads right? Are you having the block decked any? If using a .038 to .040" head gasket you'll want your pistons to be "in the hole" @ .005". That will give you an almost perfect quench distance of .045".
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
eric lavine
Did anyone ever check out Deltacams.com?
just curious |
eric lavine
probably keeps them really busy, Tr that was for you
Quigs85SN2001
Groupie Joined: September-30-2006 Location: Davisburg, MI Status: Offline Points: 67 |
Call Cam Research- all they do is Fords, and they know ski boats. Be sure to tell them that you have a reverse rotation engine. Also have your head, intake, CR info, etc handy, as theyll want that to make a good recommendation.
Thanks for the information! I found a local guy who can grind me a RR cam, but Cam Research is about $100 cheaper. It looks like a few guys on CCFan have used Cam Research. So, between a better price, and a good track record, I think I'll go with Cam Research. I know a few guys have expressed interest in reverse rotation roller cams. The local guy I found can grind them, but they'll set you back about $700! Just thought I'd mention it in case anyone is still looking for one. |
Brian
gigem75
Senior Member Joined: November-12-2005 Location: United States Status: Offline Points: 239 |
Great information, thanks!
Call Cam Research- all they do is Fords, and they know ski boats. Be sure to tell them that you have a reverse rotation engine. Also have your head, intake, CR info, etc handy, as theyll want that to make a good recommendation. http://camresearchcorp.com/ |
Quigs85SN2001
Brian A,
I haven't gotten that far yet, any suggestions? The machine shop said to put the old one back in, it looks fine. If I'm going to all this trouble, I think I want something a little hotter than the stock cam. |
Brian
nuttyskier2002
Brian Q.
Very good! Glad that someone could use them. What cam are you going to be using? Just curious. |
Quigs85SN2001
Brian A,
I took those pistons to the machinist this morning. He thought the one piston should clean up alright. Thanks for your help! |
Brian
nuttyskier2002
Gig, I agree with Joe. Sometimes the block just won't clean up to .020. Remember that is the total overbore. The cutter on the boring bar is actually only cutting into the cylinder .010" to get that (even less....you have to save some metal to hone). So for a block to be able to clean to .020 the ridge (where the piston ring tops out) can only be a maximum of about .007 to .008". I've seen blocks with well over 100K miles and only have a .002" ridge. Then I've blocks with less than 90K and have over .010". Just depends on how well is was maintained and how much it was abused. |
nuttyskier2002
Brian, I sent you an e-mail to your comcast address. I still have the pistons. Brian |
JoeinNY
No, .020 over pistions are available and 351w blocks are bored .020 over all the time. He may mean that your block needs to go .030 to get past some cylinder issues, he maybe pushing parts he has on the shelf, or he might just be a dumbass...
gigem75
my machine shop person/tech/mechanic/machinist/guru told me .030 was the min that a 351 would be bored. That sound right?
Quigs85SN2001
Brian,
I finally got word from the machinist this morning that .030 over will work. I'd like to buy your pistons, if they're still available. Let me know how you would like to proceed. My home email is margaret48350@comcast.net |
Brian
gigem75
just got the news from the machine shop, one cracked head and will need to go 30 over. He's done several marine apps and says he can get the main seals. Ordered them today from skidim but the rear main is on backorder but they seemed pretty sure it would be to them in a couple of days.
nuttyskier2002
Yes, that's the principal. It's sometimes called quench because when the combustable gases are squeezed tightly between the large flat area of the piston and the flat part of the cylinder head, the gases are somewhat cooled by the coolant passage in that part of the head. This keeps the mixture from reaching a high enough temperature to self ignite in that area. Also, this squeezing creates turbulance which keeps the air and fuel mixed for better combustion.
gigem75
no problem I didn't think you did really, just making sure, thanks!
Interesting term "quench" I guess it's similar to "squish" in say a Sea Doo two stroke. it's ususally measured by putting a piece of solder in through the spark plug hole and bringing the piston up and squishing the solder and then micing it. Putting on a different thinkness cylinder base gasket changes the height the piston reaches. |
nuttyskier2002
Mike, I did not mean to imply that D shaped pistons are rear, in fact they are quite common. But what is not common on a stock engine is to have a deck height/gasket thickness (quench) of .040 - .045". This is where the added attention to detail comes in to play. Most modern Chevy small blocks came from the factory with this quench set to .060 - .065". I'm unfamiliar with Ford's numbers. A Ford guru will need to chime in here for this.
gigem75
I found this site very interesting on gt40p heads
http://www.stangpro.com/html/articles/gt40p_files/gt40p1.htm |
gigem75
Interesting, the pistons I pulled out of this motor have a "D" shaped recess in the top. Is that stock or do I have some additional things to consider?
nuttyskier2002
These pistons have a D-shaped recessed area and are sometimes called "quench type" pistons. They work great with GT40P heads. If you don't buy mine I recommend you buy some that are similar. After your machinist bores and hones the block to the piston, have him do a mock-up assembly of the crank, 1 rod (bearing included) and 1 piston. Then measure the deck height (The distance from the blocks deck to the top of the piston). Not sure on Fords but most Chevys have at least .025 deck height above the piston. The idea here is to get your deck height and your head gasket thickness to total up to .040" to .045". Milling the blocks deck may be required if you can't obtain the right gasket. Some say .040" doesn't leave margin for error so shooting for .045 will give a little breathing room. More than .050 some say is not an effective quench height. Silvolite's website talks about this in detail so read up on it more before you decide. SBFs and SBCs are both "quech type" engines due to the way that the combustion chamber is shaped and both engines can take advantage of this added detail. But many builders don't take the time to set them up this way unless you request it. Anyway, read Silvolites website article on quench.
The advantage to setting the quench height is that your engine will be able to handle the added compression of the GT40P heads without having to run premium fuel. So why doesn't the factory set new engines up this way? They used to back in the 1960's and early 70's until the EPA came down on the industry for tail pipe emissions. Quench is not good for HC emissions. |
eric lavine
thats a good sign
Quigs85SN2001
Hi Brian,
My guy won't bore until he gets the new pistons. It is amazing to me how hard it was to find a good machinist in the Metro Detroit area! I am installing GT40P heads, and would appreciate any hints you might have. |
Brian
nuttyskier2002
Brian
Kool,....don't let him bore the block 'til you give him the pistons first (no matter where you get them from). Also, make sure he bores and hones for the clearance recommended for marine use. Are you going to be installing GT40/P heads? If so I have some tips for you about your block. Brian |
Quigs85SN2001
Thanks Nutty! I haven't heard from the machinist regarding the bore size yet. If your .030 will fit the holes, I'll take them. If not, . I'll let you know as soon as I hear from him.
Brian
nuttyskier2002
Quigs, I paid $100.00 for them and don't care to make any profit. I'll let them go for $80.00 plus shipping. If you want pics, I'll be glad to post a few. Again,... one of them is slightly galled and your machinist might want you to buy a new one. The other 7 are in great shape. Thanks for asking! Just let me know. Oh... sorry for the delay, I've been very busy the las few days. Talk to you later! |
gigem75
and have him have 150 more hp than ME? I guess I just look this way:)
eric lavine
sneak it into your friends
gigem75
hummm, very interesting, That will be something I'd do with mine, this is just for a friend of a friend and it's going back stock. Now for my motor, that would be a great winter project. Was out yesterday and the weather was perfect!
eric lavine
Gigem, mopar 318 rods, chevy 5.7 pistons your block and you get a 372 stroker, i believe the article said around 400 ponies, i gotta find the article...it was real interesting and very cheap to do this because all the parts were from stock engines, i think the biggest part of the machining was to get the rods to fit the wrist pins of the bowtie pistons
