belt - smoke |
rhschnauss
Newbie Joined: June-02-2008 Location: United States Status: Offline Points: 30 |
Posted: June-02-2008 at 4:31am |
bad bearing most likely. Someone showed me a trick to figure out which bearing. The one that is seizing up occasionally will be much noisier than the rest. Take a long extension bar for a socket set, put one end at each bearing and the other to your ear with the motor running. If you can detect more noise from one of them, you have found the one that is failing. Worked like a charm when the idler pulley was going out on my car.
rhschnauss
tjeffery72Mus.
Groupie Joined: December-23-2006 Location: United States Status: Offline Points: 45 |
I would pull the belt off and see how well that pulley is turning on the alternator, check all of the pulleys and see if the bearings are turning well, if there not im sure there is some kind of way to lube them, maybe, or might have to replace one.
The Guy.
bsucics
Senior Member Joined: July-18-2006 Location: United States Status: Offline Points: 109 |
Out skiing today and smelled something burning...popped the engine cover and smoke poured out. After it cleared, started up again and immediately saw smoke from around the alternator, apparently from the belt? Belt was very hot to the touch. Haven't seen this happen before. I waited a minute, started again and eveything appeared to be fine (finished skiing). It didn't appear that the belt was loose/slipping - would it cause any problems if it was too tight? I'd rather not chalk this up to a fluke...
