Another water leak |
jayc
Senior Member Joined: May-26-2008 Location: United Kingdom Status: Offline Points: 127 |
Posted: June-02-2008 at 7:56pm |
My 82 was leaking quite a lot through the speedo tube entry points on the transom and also through the platform bolts.
A whole load of sealant after its cured! I found it strange that the speedo entry point is below the waterline. On my MC its just about the water line preventing any leaking issues if the sealant shrunk. |
1982 Nautique 2001 - 351W Dual Fuel
1982 Ski Tique - 351W Dual fuel 1996 Maxum 210ss -350 EFI Dual Fuel |
eric lavine
i think we coined a new phrase on this site "dirty little nuetral"
Towman
Groupie Joined: June-22-2006 Location: United States Status: Offline Points: 76 |
Thanks Eric I realy did not want to pull it out of the lake but I would rather be safe.Why checking for the leak I also discovered I have a Dirty nutural so we might be talking at the end of the season.
eric lavine
you could raise the tongue and do the reverse...fill the bildge with some water and look for the leak on the outside....do i have to write this, dont fill the water over the trans, tilt it high enough so the water stays in the back, this way you dont have to remove the gas tank on your search and if it is some screws leaking you could possibly remove them from the outside and 3m 5200 them
Towman
Thanks
Towman
I have had my 85 in the water for a week now and about every day an inch of water needs to be pumped out.Not leaking at the packing or rudder,Removed the rear floor and wiped it down.It looks like its coming from the transom area behind the tank?Maybe Exhust area or platform screws???
