Holley 4160 for 4.3l motor |
Author | ||
straylight
Groupie Joined: July-05-2006 Location: Germany Status: Offline Points: 60 |
Posted: June-12-2008 at 5:59pm |
Sadly enough, it's not that easy over here in Germany, because finding parts for holleys is a bit difficult and very few people are still doing crabs anyway...
Yep, i'll do that. Thanks again, Tom |
straylight
After having i final look at the carb, i should probably replace "brandnew" with "rarely used" ;) Tom |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
If its a 600cfm, then it will work on your 351w. Jetting and PV size may vary between list numbers, but those can be swapped easily.
The 50419 sounds familiar- its probably the original 600cfm. You can call the Holley tech line and they should be able to tell you the differences between the 2 carbs. |
straylight
Hi again,
my current carb has LIST-50419-1. The other one is LIST-7053-1. At least the latter is a 600cfm carb. I can't find any information about the first one. It has an EC-number which is some kind of european approval number. The latter has (if uncahnged) the following specs: Part No.: 0-7053-1 Model No: 4160 CFM: 600 Primary Venturi Diameter: 1-1/4 Secondary Venturi Diameter: 1-5/16 Primary Throttle Bore Diameter: 1-9/16 Secondary Throttle Bore Diameter: 1-9/16 Any ideas wether this will work in a 1988 SN 2001 with the stock PCM Ford 351? Thanks again, Thomas |
straylight
they both have 600cfm, although I don't think both carbs will have the same LIST numbers. It could be either Holley Part No. 0-80492 or Holley Part No. 0-80551. What are the other differences? Baseplate, gas-inlet? TIA again, Tom |
Depends- you need a 600cfm. You can look it up by the LIST number.
straylight
Hi,
i could buy a brandnew Holley 4160 Carb with electric choke for little money. It was originally ordered for a 4.3l motor. Will that work as replacement for my old Holley 4160 on my PCM 5.8l Ford? TIA, Tom |
