  New Posts New Posts RSS Feed - How do I remove the floor?
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Topic: How do I remove the floor?
    Posted: December-27-2004 at 2:59pm
If its a DD it will be like my 2000. You have to take the whole back end out. Start with the drivers side bolster( bpadded side rail. It is held to the fiberglass with 7-8 nuts about 7/16" Remove this so you can get the back deck out. Then remove the engine cover, middle floor board, and rear seating. Then remove the 2 plastic covers bolted to the rear deck section. 1 covers the fuel filler hose and 1 the vent tubing. After removing those the back floor will come out. There are 2 stainless straps holding the gas tank down the nuts are 1/2" I think. Remove those and all the hoses. Make sure you mark the pickup and return hose so you donn't mix them up/. The emptier the tank the easier it is to remove. After removing the tank you have open access to the rudder and cable. While your there I would recommend repacking the rudder gland with 1/4" Teflon flax. Also check the muffler for leaks and tighten all the exhaust hoses. It took me about 3.5 hours to do all of the above.
97sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 97sport Quote  Post ReplyReply Direct Link To This Post Posted: December-25-2004 at 2:32pm
ryan, on my 97 sport you have to remove the engine cover just 2 pins. then remove the rear seat again just 2 pins then lift out the center of the floor exposing the middle of the boat. Very easy to do. Also good time to check your engine alignment.
life is short live it!!!
Ryan S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan S. Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2004 at 4:20pm
Sorry I forgot to mention that my boat is a 1997 (19'6"). Thanks
Ryan
oldcentury76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldcentury76 Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2004 at 8:30pm
what year boat do you have???
My boat I have to pull up the middle wood piece behind the engine cover.
1976 Ski Nautique
Too many hobbies, not enough time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan S. Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2004 at 5:11pm
Happy Holidays. I have a need to get to my rudder (tiller arm) to adjust my steering cable. How do I remove the floor to get there? I'd appreciate any advice/experience? THANK YOU
Ryan
