has anyone seen this? |
kevin719
Senior Member Joined: June-18-2008 Location: United States Status: Offline Points: 231 |
Posted: July-03-2008 at 6:20pm |
I guess the correct terminology would be a recipricating saw! Sawzall is Milwauki brand and the most popular.What is really nice if you are looking to buy one is the rechargeables!Dewalt makes a good saw as well! I used a 12" demolition blade (wood/nail)to cut my floor out and it could not have been any easier! I highly recommend this method of removing the floor!
kevinindy
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
Here is a link to a website that has a good assortment of blades & their use. I just buy mine locally, but this does show what there is.
You can get a general purpose blade that works for several materials. Blades |
lewy2001
Thanks skicat. How long are the blades on them puppies. Also what type of blade do you use to remove floor? Wood? metal? plastic?
skicat
lewy2001
I keep hearing about this sawzall. It must be another terminolgy difference between US & Aus. Pic please
kevin719
I tore out my flooring today.Thanks for the sawzall tip it made life easy!! I have a 74 southwind and I believe that I am removing stock flooring! on the sides the floor is sectioned off into squares.These squares were filled with foam and had 2 4 inch or so strips of wood running down the middle.The floor sat on top of that.These square cavities are pristine!Minus the wood! There is only a veneer left stuck to the glass.This system just does not look very strong??Any suggestions for improvements?The cavities are also watertight my boat has been inside for several weeks and these boxes had quite a bit of water in the bottom.The foam was a little wet as well.Thanks for any help or suggestions,this is my first attempt at this and I like my boat too much to do a half a-- job!Yes I have drilled many holes in stringers and the wood is great.Top and bottom. Thanks again guys.Kevin
kevinindy
