Ballast pump fuse? |
pbrmn
Newbie Joined: July-08-2008 Status: Offline Points: 4 |
Posted: July-08-2008 at 11:26pm |
I found it! (After phoning a dealer and getting a vague description). For anyone else who may encounter this (apparently these fuses blow fairly frequently) the fuses are located in the starboard gunwale about half an arm length forward of the back locker. I had to remove the lockers floor and half climb into it with a flashlight in my teeth.
Phil |
pbrmn
I am unable to drain my port ballast (2006 216 Team edition). Is there a fuse somewhere as well as the CB below the dash? The pump does not run but the CB is not popped. I just got this boat and this was only the second time I had filled the ballast tanks. Are the pumps prone to failure?
Thanks, Phil |
