What shaft packing to use 97 Super Sport. |
SNobsessed
Posted: July-22-2008 at 7:38pm |
[QUOTE=Booty] OK so how often is the Goretx almost dripless packing supposed to drip? QUOTE]
It took me a few tries to get it right but mine drips maybe 1 per minute. I went from too much leakage to too tight (packing box would heat up) in about 1 hex flat of adjustment. Now it is great, get about 8 ounces of water all day, box stays cool. |
dcoll
Senior Member Joined: August-06-2006 Location: Manchester, MD Status: Offline Points: 122 |
I assume the packing size is 3/16".
1997 Super Sport Nautique
Booty
Groupie Joined: July-30-2007 Location: United States Status: Offline Points: 46 |
OK so how often is the Goretx almost dripless packing supposed to drip? I set the flax packing to drip every 3-5 seconds of course there is a descussion over how often but what about the dripless? how often?
Booty
82,2001 82,2001 |
dcoll
Thank you 8122pbrainard. I will go with the Gortex.
Booty, I believe there is a water line attached to the seal for cooling. |
Booty
Just wondering with the dripless seals that some are using ,what affect does it have on the shaft. I thought you needed it to drip to cool the shaft where the packing meets the shaft as well as lubricate it? what are your thoughts on it. I like the idea of the dripless packing, just wondering
Booty
82,2001 82,2001 |
Dan, The newer Gortex "almost dripless" packing is really great stuff. It really is a major leap over the old flax type and so much that I now question the need for a fancy/expensive dripless seal system retrofit. The retrofit to a dripless also requires the removal of the prop shaft which can be a real challenge at times especially if you don't have a double taper prop shaft. Joel (M3fan) just went through the exercise of installing a dripless a couple months ago and I got the impression he wished he never started the project!
dcoll
I will be removing the the trans to inspect and since I will have access to the shaft packing, I was going to replace. It was dripping pretty bad. No way of access without removing the rear seat back rest. I see diff materials for packing and 2 diff dripless shaft seals on Skidim. I am totally clueless. This is my first inboard. Please guide me oh great ones.
Signed Totally Clueless |
