  New Posts New Posts RSS Feed - Solenoid?
Solenoid?
Busted Knuckle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Busted Knuckle Quote  Post ReplyReply Direct Link To This Post Topic: Solenoid?
    Posted: July-30-2008 at 1:24pm
Originally posted by 88 Nautique 88 Nautique wrote:
Low voltage on the "start" terminal on the solenoid, (from your ignition/start switch) will cause this problem. My new solenoid did the same thing so I checked the voltage on the start terminal at the solenoid with the starter disconnected from the solenoid and the key switch in the start position. (Note: don't hold the key in the start position for a long time. The solenoid is a momentary relay and will burn the coil open if left on a long time.) Should be close to 12V. If you're getting a reading of 9 volts or less, check your circuit path for a corroded or bad connection. You can usually clear the stuck solenoid by tapping on it after disconnecting the battery.
What I found on mine was from a corroded termination from the engine wire harness at the breaker on the dash.
Low voltage will not "slam" the contacts together. The electromagnet will slowly engage causing the contacts to arc and weld together, causing your starter to run on.
Kurt
this is the path I'd take.......... been here several times, old boats , old wire = low voltage
Volante Barefoot Skier built by American Skier Boats -
www.footngear.com
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 9:19pm
I'm going to buy a new solenoid and go from there. My optima D34M is brand new so not concerned with it. Just curious on the technology. I have had no problems with cranking power.
thanks!
88 Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 7:45pm
David,
Here is a good explanation on marine batteries:
Marine Batteries
What Peter says is true for a deep cycle conventional battery. They are built for constant draining and charging. If you do that with a start battery, their life will be shortened. Can be used in an emergency though. The same with using a start battery as a deep cell. That will shorten the life as well.
Optima doesn't have plates per say. They use what they call their proprietary Spiral Cell technology. That's why the batteries look like there are 6 jar type batteries in the case. They don't say why their batteries are dual purpose, but I have an email into them for some technical explanations. Here is the site for the Optima D31 tech sheet. It boasts a 900 CCA:
Optima D31M Data
I will not try to convince anyone to buy an Optima if they feel they can't be used as a cranking battery. Optima says the dual purpose batteries are designed for this and I have been convinced it's true as I haven't had one fail on me YET. Knock on wood.
I would check for the other problems I mentioned before buying a new battery though. Also you might take your starter out and have it diagnosed if my other suggestions don't pan out.
Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 3:22pm
Does anyone have an explanation for how a dual purpose battery works?
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 3:02pm
To add,
a deep cycle battery has higher internal resistace. Just a few tenths of ohms doesn't matter till you pull 100+ amps and the V-IR and you loose 4-6V at the battery.
The starter is a DC motor, and pulls more amps the slower it goes, so you then have a runaway train of heat and wasted energy and smoked cables, starter and solenoid.
When a starter stalls its like a dead short, and pull major amps, but those big amps pull the voltage down further on a DeepC battery due to its internal resistance.
Less applied voltahge means less work done my the motor and more waste heat on all components
The lower available voltage also has less clamping force on the solenoid contacts, which then gets resistive, heats up, and welds its contacts together from the arcing across the contacts.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 1:49pm
Originally posted by stepper459 stepper459 wrote:
Originally posted by GottaSki GottaSki wrote:
Starting (good) or Deep Cycle (bad).
Here's a stupid question: why is a deep cycle bad?
I know of at least one person who will disagree with me but he won't mind me speaking up! A deep cycle is designed for smaller amp discharges over a long period of time whereas a starting is the opposite and will handle a high amp discharge for only the time it takes to start the engine. The design of the plates and insulators between them is different in the two battery types. It is said that you will warp the plates of a deep cycle if used for starting and harm the battery. If you use a start battery for a deep cycle and take it down past it's 11 volt design, it will harm it. The battery will never take a full charge again. A deep cycle can be taken down to about 6 volts without harm.
stepper459 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stepper459 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 1:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 1:14pm
The battery is a dual purpose Optima Bluetop.
I'll go to Carquest and see if they have a standard auto one. I think that's whats on there now.
Thanks.
bill1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill1 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 1:05pm
replace with which ever one is on there now, that is if it works and starts good.
bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 12:35pm
Originally posted by vondy vondy wrote:
The battery is new as well so none of those.?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 12:01pm
I'll test the voltage at the solenoid. The battery cables are brand new 1g marine grade. The battery is new as well so none of those.
Have y'all been replacing with standard automotive solenoid or a marine grade?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 3:51am
Kurt
Booty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Booty Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 2:50am
Once they stick the contacts arc to each other internally and cause a rough spot from prolonged contact and high amps from the battery. It will continue to do this so go ahead and replace it,this will keep you from continously turning over the starter until you can get the engine cover up and tap on it to make it release. Or the boat will start and want to keep the starter engaged and destroy the bendix on the starter and damage the flywheel as well. this is common . It's a PITA to get everyone out of the way to open the engine cover and puts undue strain on the starter as well. You may look at how old positive battery cable is as well . If it has lots of corrosion and is burned up at the positive connection at battery post. Low voltage to solonoid can make this a reoccuring problem. been ther done that
Booty
82,2001 82,2001
tommer12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 2:28am
For sure the soleniod. The internal component of that is probably sticky. It's normal for these to go out. You can take a hammer and tap on it to loosen it up, but eventually it will fail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2008 at 2:12am
So when testing my engine, there was a couple of times when the starter did not kick off. We had to unhook the battery to stop it. My dad thinks it's the solenoid mounted to the engine. Any thoughts? Would this one be a good replacement?
http://www.go2marine.com/product.do?no=93957F
Seems like whatever is on there now is a standard automotive solenoid.
