  New Posts New Posts RSS Feed - Exposed wood in stringers
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: Exposed wood in stringers
    Posted: January-25-2005 at 12:05pm
"The Fiberglass Boat Repair Manual" is a good book to start with. Also, I think West Epoxy Systems prints a workbook that has good information.
What type of resin are you working with? If epoxy, you should avoid getting the resin on your skin as epoxy can and WILL eventually cause skin allergies with prolonged exposure. Once you get these allergies, you will break out in hives just by getting near uncured epoxy. The allergies stay with you.
I found the best way to keep the resin off your hands is to wear latex gloves (or PVC gloves if allergic to latex). The gloves are available in 100 count boxes for very few dollars. Acetone is indeed the best solvent to use for clean-up, but lacquer thinner will work and is a bit cheaper. Just remember that after you clean any tools in the solvent, do not stick your hands in the solvent as it is now contaminated with the epoxy chemicals that cause the skin allergies.
And lastly, then I will stop with the warnings...the build-up of the allergy causing chemicals is cumulative in your body. So, incidental contact may not cause the allergies, but it gets you that much closer. So keep it off your hands.
Oh, and about covering your new/patched fiberglass floor with carpet. Do not worry about getting the floor perfectly smooth with no hollow spots or humps as you will not be able to feel or see these areas once the carpet is in place. If you are laying the floor up over structural foam, then I would think five alternating layers of mat and roving will suffice (assuming 1.5 oz. mat).
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2005 at 9:28pm
Thanks David,
I need a good book (with a lot of pictures) on fiberglassing. I am presently making a new floor. I can tell you that fiberglassing is a lot like hanging wall paper, the small peices with a lot of corners and curves are terrible. The best news is I will be covering it all with carpet.
For all of you beginniners, buy a large can of Acetone, soap and water does nothing for clean up and your keyboard keys will stick to your fingers.
Anyone know of a good book?
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2005 at 8:07pm
Jim:
You will be fine using the products mentioned above. I strongly suggest you do as you mentioned and cover the exposed stringer with several layers of fiberglass mat and cloth (alternating) to equal the original thickness of same. Most of the strenght of the stringer comes from the fiberglass, NOT the wood. Think of the wood as just a form. The wood actually has other benefits such as noise and harness control and a good material to hold screws/lag bolts (i.e. engine mounts.). Also, FWIW, use epoxy resin when working with fiberglass, it has superior strength over Polyester resin, is a superior adhesive (important when making secondary bond repairs) and does not shrink like polyester resin. Just make sure you find and use fiberglass mat made for epoxy resin.
Almost forgot, another option is to simply cut/dig out the rotten wood and then scab in a new piece (epoxy glued and screwed) and then fiberglass over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2005 at 1:42pm
This is what I needed to know. Thanks! A few months it is. (I have a back-up boat to enjoy while waiting - my '68. ....and my friends asked why I need two boats. I think I may need three.)
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2005 at 1:31pm
You might want to us a dehumidifier as well. if you use a heat source make sure there aren't any flamable fumes close by like gasoline, epoxy. the fire will dry things out pretty quick but there's not much left to work with afterwards.
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2005 at 1:18pm
BRAVO 79 ! you are absolutely CORRECT.it takes a long time to completely dry out.
jim.you could speed up the process.the heat lamp is a great idea.maybe u have a small electric heater to set inside then build a tent over the boat,but allow for air circulation.
also,i used a product i found at home depot.
MINWAX high performance wood hardener.same as rot-doc only cheaper.formulated to strengthen and reinforce decayed or rotting wood.$8 a pint.the barracuda wasn't that bad.after the minwax stuff i painted the wood with a 2-part epoxy.hope this helps.
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2005 at 11:31am
You might want to let dry a little long than that. Depending on how soaked it is it can take several months. Wood that isn't exposed will be wet and takes a long time to dry becuase it's covered still, so let dry as long as possible before you have to put everything back together for the season. Once it is dry the Dr Rot stuff will take a week-end to complete you can apply more CPES about ever 1/2 hour to hour and it cures in a day or two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: January-19-2005 at 9:00pm
Thanks for the input. I'm thinking about pulling the engine, draining the gas, and applying a heat lamp with a small fan to the stringers for about 2 weeks. I think I can dry it out. The Dr. Rot CPES sounds like the way to go. I need an a-frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: January-19-2005 at 7:58pm
You are going to have to let it dry out pretty good before you use the Dr. Rot CPES. but once you use it it will be hard as a rock. On mine the rear 1x6 that goes between the stringers to the rear was rotted out and half gone I applied the CPES and it's like petrified wood now. Just apply the CPES repeatedly until the wood will not soak up anymore per MFG instructions. Then glass over any exposed wood and enjoy the summer. Now i'm sure there will be others that will say remove the stringers or a section of them and replace and re-glass. This is a lot of work and can get expensive and if you work full time then most of your summer is going to be shot working on the boat. Dr. Rot is quick easy and works. Now if your a purist and plan on keeping the boat for ever then maybe you should spend the time and replace the stringers but if you do get experinced help/supervise your work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: January-19-2005 at 6:03pm
Well, I am just digging into my '66 and I have discovered that much of the stringer has delaminated fiberglass pulling away from the stringers and in many spots bare wood is showing. In one of the spots the wood, under the motor mount, appears to be soft.
I'm considering wire brushing and cleaning all of the stringers, removing all loose fiberglass, treating the bare wood with the Dr. Rot stuff, and recovering all of the stringers with fresh glass and resin.
Any opinions on this? I really want to avoid replacing stringers. Maybe a stringer board can be placed along side the old stringers and be screwed, glued, and glassed to the old stringers. Like most of us I have zero experience in this area. Thoughts? By the way, the old '66 has no foam in it except under the gas tank mounts and behind the front kick-pad. Interesting huh?
