  New Posts New Posts RSS Feed - high temp
  FAQ FAQ  Forum Search Search  Register Register  Login Login
high temp
Richard Wong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Wong Quote  Post ReplyReply Direct Link To This Post Topic: high temp
    Posted: January-25-2005 at 1:04pm
I'm a owner of 2001 Super Air Nautique,
My name is Richard recently the temp. meter showing abnormal high temp.(going over 180F),whgen I use pipe to flush the sea water cock inlet on land,I find water not goout exahust pipe but goout bottom of the boat there i see a water inlet/outlet, I trace this out/inlet connected toa T shape pipe connector,that is white plastic T joint,seems has valve funtion, I think that is the problem, Any friend know what is that and where can order and the cost? the position is uder the fuel pump.
