How bad is this prop? |
Author | ||
jbear
Posted: August-26-2008 at 3:01am |
Guys like me and Gary S sure can agree with this. Don't know if I'd like OT in your line of work tho. john |
"Loud pipes save lives"
79Tique
Senior Member Joined: September-04-2006 Location: United States Status: Offline Points: 380 |
Never tried changing one in the water. I don't carry a hole lot of spare parts. If I'm a long way from home I carry a spare prop/puller, raw water pump impeller and a tool box with some misc. wire, tape, clamps and chunks of hose it it.
None of it is on the boat; it's in my truck at the ramp. On the boat I have a Leatherman tool and a roll of duct-tape. Knowledge of how the systems work and go together can get you through a lot in a pinch. |
Work to live, not live to work.
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1334 |
anyone ever changed a prop (on an inboard)while the boat was in the water?
Where do you guys carry all these millions of spare parts? I can't find enough room on my boat for all of them. |
Mullet Free since 93
95 Sport |
79Tique
If you're gonna carry a spare prop you better carry a prop puller as well. Otherwise your likely to get frustrated at the ramp and damage something trying to get the damaged prop off.
When I'm a long way from home I carry my puller a spare prop and a couple extra cotter pins. You can get a quality puller for about $80.00. Discount Inboard Marine has a cute "spare prop" case that has a pocket for the puller and a wrench for the nut. If you're looking to put an extra $125 in to the deal. Mine lives in a cardboard box. |
Morfoot
I too recommend Delta props. The've straightened a rudder shaft and fixed 3 props for me. Suckers looked brand new. Figure bout $100.00 to do the job not including shipping. quick trun around time too. Well at least in the spring.
wakemeup
Senior Member Joined: July-11-2008 Location: Culver City, CA Status: Offline Points: 113 |
Just for the record, he actually just said get a spare. I misquoted him about specifically buying a 4 blade. |
Wakemeup
1988 Ski Nautique 1999 Air Nautique |
eric lavine
thats a pretty hard hit, check the shaft run out after the strut, i would bet its tweeked, but im not a gambling man
Not a good idea! Do some research before you spent big bucks! |
wakemeup
Thanks guys! George |
Wakemeup
jbear
Always carry a spare.
john |
When here at home no need to carry one,but when on the road,yes I bring one. If you don't you could loose the whole weekend for a 1/2? hour job.
74SkiNautique
Senior Member Joined: July-29-2008 Location: Lynchburg, VA Status: Offline Points: 228 |
I would Reccomend getting a four blade prop. OJ is the best way to go, it looks like that is what your prop now is. Also, b/c I know my lake very well, i dont carry a spare prop with me. I have my old 3 blade In the shop. Its good to have.
74SkiNautique
wakemeup
Well this is all better news than I thought, I like the idea of going to a shop with a computer diagnostic to repair. Thanks for all of the input.
I've seen several references on this sight to having a spare prop. Is a spare prop something you would bring with you to the lake to replace a totally trashed one? Is it practical to be able to change out a prop on a Saturday or Sunday at the lake without having the whole weekend ruined? If so, how many of you guys carry a spare prop in your tow vehicle? You probably know where I am going with this. I am thinking of doing what Chris suggested; getting a four blade, repairing this one and having as a spare. But it doesn't make a whole lot of sense to have a spare unless you can change it out to salvage an outing at the lake. I mean I can get one overnighted to me tomorrow. |
Wakemeup
BuffaloBFN
Delta Prop is a site sponsor(banner at top) and did excellent work for me.
JohnI
Newbie Joined: August-22-2008 Location: United States Status: Offline Points: 1 |
Wakemeup -
Your prop is very fixable. I recommend you send it to a prop shop that uses a "Prop Scan" computer diagnostic equipment for an accurate and balanced prop. I've used Thomas Marine Propeller shop in Sacramento that uses the "Prop Scan" computer system and the results were outstanding compared to the conventional prop shops that just use blocks. If you google Thomas Marine Propeller you can get a better idea on their work. They're not inexpensive, but worth the price. |
bill1
Senior Member Joined: May-27-2007 Location: United States Status: Offline Points: 151 |
wake, if you have been running the boat with that prop you should be feeling a lot of vibration. mine had just a few nicks and i had it redone this past off season. now i ride smoothe as butter.
bill
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
I would think that should be fixable. Do a search on prop shops and you should be able to find some recommendations.
If that's an acme maybe you can send it back to them to bang back into shape? |
79nautique
yes send it off to get straighted out/recondition and then use it as a spare and get a new prop if you have the budget to get a new one otherwise get it fixed and put back on the boat. Also you need to double check the alignment so that your not replacing the prop shaft next.
wakemeup
I need an expert opinion on the condition of my prop. Check out the pictures and let me know what you think. Does it need to be replaced? Can it be repaired? How much will it effect performance? By the way the PO did it. Two of the blades are damaged.
Thanks for your advice. George First blade thats damaged. Another angle of first blade. Another angle of first blade. Second blade thats damaged. Whole prop showing both damaged blades. |
Wakemeup
