Filler neck gorunded? |
74SkiNautique
Senior Member Joined: July-29-2008 Location: Lynchburg, VA Status: Offline Points: 228 |
Posted: August-28-2008 at 11:09pm |
Yea, when i install the tank tomorrow, ill run a wire over to the ground of the tank. I have to redrill my filler neck holes anyway, so one will have a nut on the end where i can put it!
74SkiNautique
eric lavine
good insurance if you dont!!
MdFooter
Senior Member Joined: January-30-2008 Location: Lakeland, FL Status: Offline Points: 100 |
It wouldn't happen out on the lake, it would happen when you refuel. Same reason why aircraft are grounded three ways during refueling operations.
BL: cheap insurance to run a new wire. |
74SkiNautique
Thats what my dad said. So we will run a new wire to the ground for the tank, this way, we cant die out on the lake!
74SkiNautique
eric lavine
its there for a reason, i would probably say for static spark when filling the boat
DrCC
Yes
74SkiNautique
I took my tank out to replace all of my exhaust hoses. I found a small yellow wire stuck in the filler neck hose. Does my filler neck need to be grounded to the tank?
74SkiNautique
