  New Posts New Posts RSS Feed - Exhaust manifold help..
79nautique View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust manifold help..
    Posted: February-04-2005 at 9:56pm
Just replace the manifolds and have the risers diped at the local machine shop, repaint them and they will be fine. Call j.a.chamberlain and get the PCM exhaust manifolds for around 150 each.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2005 at 7:12pm
The risers are where you could have bolts break off. You shouldn't have any trouble taking them apart from the heads. If the heads of the bolts are in bad shape, Craftsman and Irvin make a set of tool-like sockets with a spiral cut which will take off the worst rounded off bolts.
Tim D
wakegoddess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakegoddess Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2005 at 5:39pm
I bought an 84' sn 2001 last April. I developed an exhaust leak in one of the hoses and recently replaced both sides, I am sure they were the originals as they had the original carpet wrapped around them. I also took both risers off to replace the gaskets. The manifolds are both really rusty and several of the bolt heads are in bad shape, they would be inpossible to take off with out grinding them. I dont know of any leaks in the manifolds....yet. Should I just replace everything now? or wait. I am sure the manifolds are also original. My boat has over 1000 hrs. on it. How big of a job is this going to be to get them off? thanks!!
