Tune up a HM302 |
h20loo
Senior Member Joined: August-30-2008 Location: Canada Status: Offline Points: 225 |
Posted: September-10-2008 at 10:22am |
Gary- thanks, that is exactly what I needed. I checked a few other sites but didn't find part #s. I have the Motorcraft plugs in it now and will continue with them. I see most of the guys have 8 mm wires and I'm familiar with those Accel wires. Thanks Doug |
70 Mustang project
Doug, here is a little of the info I have.
http://www.eastmarine.ru/incp/katalog/sierra/i_o/OMC_STERNDRIVE_COBRA/ignition_system.pdf on this site are some part #'s Tune up kit 1st page,right hand column,bottom AP 3077, or cap alone, 3rd page,1st column 4th down AP 868,or just points,condencer,rotor 1st page middle column, 2 down AP1007. This is assuming you still have the mallory distributor. I have used these parts for years when they were known as Aqua Power. Maybe with these numbers you can go with a local parts store. The impeller for your I assume original Jabsco is part # 1210-0001 and comes with the impeller and several cover gaskets.Everything but the end plate is advailable from here- http://www.depcopump.com/ Below is a parts break down for your pump- http://www.depcopump.com/datasheets/jabsco/11850-0801.PDF For plugs I use regular Motorcraft ones,if you need the number I'll have to check the boat later and for wires I used some Accel solid core ones that you cut and put on the ends yourself. I realise you live in Canada but maybe with this info you can get them up there eh? If I can help anymore just ask- |
Tim D
I've marked several things as "gift" when sold on ebay to help people out on taxes.
Tim D
79nautique
well NAFTA was just the jobs not the products going cross borders or should we say US jobs shipped over the borders. |
BuffaloBFN
Well said! Thanks for the explanation...all you need is a boat parts smuggler. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3357 |
NAFTA my azz. That Blowz.
River Rat to Mole |
h20loo
Its not really. The problem is if I come to the states for a few days I can bring back $300/person no problem. And more if I'm there longer. If I order a $40 part I usually get charged 2 or 3 times the cost ofthe normal shipping cost within the US(it really should only be up to 10% more), 14% Canadian taxes on the declared value including shipping and then $30 brokerage fees. Its these added values that piss me off. Many times for car parts I will have them shipped to a UPS warehouse near the border and I will cross over and get them. |
70 Mustang project
h20loo
Tim- that's exactly how its done. You must have done that before. That would work but it depends on how much would be saved and how fast I need the part. When you take the savings and make it worthwhile for everybody, then you really have to be buying some expensive or US only stuff. Tuneup stuff is more important for me to get the parts that have proven good to somebody and get it today. Otherstuff like a prop purchase would be really good for a gift. Doug |
70 Mustang project
BuffaloBFN
Please excuse my ignorance, but why is it hard to ship boat parts over the border?
Tim D
Can you send money to someone and get them to buy the stuff for you and ship it to you marked gift? That would help on import taxes.
Tim D
h20loo
I'm just about to tune up a 1970 HM302 and I'm looking for parts advice. Ie: which sparkplugs and wires have worked well for you on the HM , part # for distributor cap and rotor points and condenser.
I can't use Skidim or similiar because shipping and the border is expensive and too time consuming. Mechanic jobbers is my best source but ofcourse they don't have any reference for the flat top caps. I think I have the carb under control but I need to work on the fuel supply- Also- searched alignment, vibration etc and found pages of threads and have spent two hours reading thru them but I havn't found the thread on how to align the drive. Anybody have it bookmarked? Also looked for a picture of a Mustangs stringers(being repaired) and didn't find them. Can anyone point me in the right direction there? Are the impellers hard to get? I had a look at mine and its good to go but I would like to have one on the shelf if I need one. Thanks Doug |
70 Mustang project
